78 horn mess
Old May 27, 2014 | 05:36 PM
DBez93's Avatar
DBez93
Default 78 horn mess
I'm currently residing in a state that doesn't perform inspections, so it's not of the up most importance, but my horn doesn't work... I believe something under the center cap broke for a p.o. at some point & instead of taking the time and effort to repair it, they gutted the mechanism, & slapped some disgusting black chunky (& sticky) tar like crap in it, I was wondering if anybody here had any photos of what it's supposed to look like in there, and if you could tell me the exact location of the harmonica under the hood... I'm speechless that someone could be so lazy
Old May 27, 2014 | 07:26 PM
DUB's Avatar
DUB
This may help...the tele-tilt columns are basically all the same.
http://willcoxcorvette.com/instructi...69_secured.pdf
The "harmonica" connector (so-to-speak) is not in the engine compartment.
The connector for your turn signal switch is under your steering column...and is BLACK and is a single row of terminals that looks like a harmonica.
In the connector...at one end of it...you will see a black wire...then a pink wire...then a black wire again. That 3rd wire in (the black one) is the wire for your horn. SO...if you ground it...and your horn relay is good (which is by your fuse panel area)...and your fuse is good...and the horns are good and grounded well...the horn should blow.
It will depend if the upper contact is good down the that black wire in the connector. often times I have seen the spring in the turn signal switch go bad and thus loose contact and make it so when you press the horn button...it will not work.
This is simple diagnostic....for me at least ...I must have done at least a hundred over the years. Having a wiring diagram would be helpful to you along with a volt/ohm meter.
DUB
Old May 27, 2014 | 07:34 PM
DBez93's Avatar
DBez93
Awesome, thanks dub
To 78 horn mess
