fan Motor
Old May 28, 2014 | 02:33 PM
B. Figueroa's Avatar
B. Figueroa
Default fan Motor
no power to fan motor fuses all good
Old May 28, 2014 | 02:48 PM
wombvette's Avatar
wombvette
What about wipers?
Old May 28, 2014 | 03:42 PM
FireballXL5's Avatar
FireballXL5
Those blower motors for a c3 are $15 to replace and super easy to get to... If that turns out to be your problem ... And not the switch.. Good luck
Old May 28, 2014 | 06:07 PM
B. Figueroa
the fan motor appears to be good, the switch is new but theres no power to the fan motor wires. I replaced a defective heater core and had power to the fan motor before but now theres no power ... not sure what to check next
Old May 28, 2014 | 07:28 PM
FireballXL5
Start investigating what wires are hot in, and out of the switch with a multimeter or test light... ;-)
Old May 28, 2014 | 07:40 PM
DUB's Avatar
DUB
What year is your Corvette???
Does your car have Air Conditioning????
ONLY ONE wire has power to it...the other wire is ground.
You wrote that it HAD power to it before you did the heater core...BUT did it work???
DO you have a wiring diagram for your car????
DUB
Old May 28, 2014 | 10:37 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
I have dozens of schematics on my site.. but without a year I can't help you.
Old May 29, 2014 | 06:00 PM
B. Figueroa
thank you again I found the power problem to be a faulty relay on the firewall
Old May 29, 2014 | 06:06 PM
B. Figueroa
I have a 77 vette w major wiring problems. I found a defective relay on the firewall that stopped the fan motor from getting power
Old May 29, 2014 | 11:00 PM
0Willcox Corvette
Former Vendor
They get roasted from the heat off the manifold.... usually melts the connector too..
Here is the schematic... 1977-1982 Heater control a/c schematic
Old May 30, 2014 | 01:14 PM
B. Figueroa
I think this diagram is going to help a lot thank you again!
To fan Motor
