Camber/caster/toe
Old May 29, 2014 | 07:57 PM
Wig's Avatar
Wig
Default Camber/caster/toe
I have installed my front coil overs and steroids steering, now I am in the process of doing an alignment. I have measured my camber/caster/toe. Bought a new shim pack. Do you add/remove the shims with the wheels on the ground or off?
Old May 29, 2014 | 08:05 PM
zwede's Avatar
zwede
Car on the ground. Loosen the 2 nuts and the weight of the car will force the upper a-arm inward so you can add or remove shims. Don't remove the nuts completely as that would make bad things happen!
Old May 29, 2014 | 08:10 PM
Wig's Avatar
Wig
Old May 30, 2014 | 09:20 PM
gcusmano74's Avatar
gcusmano74
Put a few sheets of shiny magazine paper under each front wheel first. This will allow the tires to move about easier when you are setting the angles.
To Camber/caster/toe
