1972 Mystery Wire
Old Jun 2, 2014 | 12:06 PM
piceezr's Avatar
piceezr
5th Gear
Default 1972 Mystery Wire
Can someone please help me identify what this wire is for? See attached pictures. It is the one in the 1st picture that I have put into a circle. It is Tan/Lt brown and comes through the firewall just under the wiper motor and is approximately 24 inches long. It is a female connection and I cannot any connectors that it should go to. Everything on the car works except for the horn and alarm system.
Old Jun 2, 2014 | 12:36 PM
Peterbuilt's Avatar
Peterbuilt
Maybe that wire goes to the idle stop solenoid on the carburetor?
Old Jun 2, 2014 | 01:00 PM
Mooser's Avatar
Mooser
Beige wire to the solenoid (Q-jet) not sure if it serves any function on a Holley
M
Old Jun 2, 2014 | 03:31 PM
Mashman's Avatar
Mashman
It is the line to the idle stop solenoid. It should have 12v whenever the ignition is on.
You are lucky, most of the time Bubba has cleaned up the engine bay, and cut the wire down by the firewall.
If you still have the emission data sticker by the drivers side firewall, it tell you have to set the idle steed with the solenoid.
Old Jun 2, 2014 | 04:17 PM
piceezr's Avatar
piceezr
5th Gear
Default Mystery wire
I believe you are correct, however, the reason I could not find a place for the wire is because the idle stop is missing. I have a LT-1 with a Holly. The car runs fine and idles without any problems. Is that something I should be concerned about? Do I need to buy the solenoid and install it?
Richard
Old Jun 2, 2014 | 05:38 PM
LT-1 kid's Avatar
LT-1 kid
I think the idle stop solenoid is so the engine will not have run on after the car is turned off
Old Jun 2, 2014 | 06:37 PM
F4Gary's Avatar
F4Gary
2018 C3 of Year Finalist
2016 C3 of the Year Finalist
I don't use the tan wire. I have the solenoid wired to my a/c compressor to bump up the idle when the compressor is engaged.
If my car wants to run on, I let the clutch out.
Old Jun 2, 2014 | 10:51 PM
riverracer au's Avatar
riverracer au
what a good idea
my auto always seems to drop off a bit when at the lights with the ac on.
my idle has been set by the linkage screw, not correct, but i bet most have been done that way
Old Jun 3, 2014 | 08:38 PM
vettefred's Avatar
vettefred
Skip Shift
Don't have one on my 72 LT-1....wire is there. It runs fine.
Fred
Old Jun 3, 2014 | 09:57 PM
ctuinstra's Avatar
ctuinstra
I wish I had that wire, I would use it to feed my electric choke coil on my Holly 4160. Still looking for a convenient 12vdc ignition wire for it.
Old Jun 4, 2014 | 12:53 PM
F4Gary's Avatar
F4Gary
Originally Posted by riverracer au
what a good idea
It doesn't work real well since the solenoid is not designed to actually move the linkage. You have to help it by blipping the throttle. Hard to get it to hold anything less than 1400 rpm too.
To 1972 Mystery Wire
