Overheating on Freeway
Old Jun 2, 2014 | 06:07 PM
charleyahrens's Avatar
charleyahrens
Default Overheating on Freeway
Most of my driving is in city traffic, stop & go almost never over 50 MPH. It have never goes much over 210 degrees no matter what the outside temperature is. It is 106 here today and most likely will remain over 100 through September. Today after 2 miles on the freeway @ 75 mph the temperature was pushing 250 with the a/c on. I turned the a/c off but did not notice a significant decrease in engine temperature. After a 15 minute cool down, I drove in city traffic for several hours with the a/c on and did not experience any issues. The car is a stock 81 with no mods. The timing is set correctly, the anti freeze is a fresh mix of Prestone 50/50, new radiator cap and new 180 degree thermostat. All of the weatherstrip in the engine compartment is in place and I have the stock fan shroud installed. My first question is, would it be a solution to replace the fan clutch with the correct length spacer? Is it possible that the bottom hose is collapsing at higher speeds? Is there a way to check for that senario? Any suggestions will be appreciated.
Old Jun 2, 2014 | 06:09 PM
charleyahrens
Most of my driving is in city traffic, stop & go and almost never over 50 MPH. It has never gone much over 210 degrees no matter what the outside temperature is. It is 106 here today and most likely will remain over 100 through September. Today after 2 miles on the freeway @ 75 mph the temperature was pushing 250 with the a/c on. I turned the a/c off but did not notice a significant decrease in engine temperature. After a 15 minute cool down, I drove in city traffic for several hours with the a/c on and did not experience any issues. The car is a stock 81 with no mods. The timing is set correctly, the anti freeze is a fresh mix of Prestone 50/50, new radiator cap and new 180 degree thermostat. All of the weatherstrip in the engine compartment is in place and I have the stock fan shroud installed. My first question is, would it be a solution to replace the fan clutch with the correct length spacer? Is it possible that the bottom hose is collapsing at higher speeds? Is there a way to check for that senario? Any suggestions will be appreciated.
Old Jun 2, 2014 | 06:32 PM
F22's Avatar
F22
It's pretty easy to check the radiator hoses. When the car is cold, go on and give the upper and lower hoses a good squeeze with your hand. They should be shiny and firm. If they feel like an grandma's arm and are soft, spongy and grey looking, then it's time to replace them.
Old Jun 2, 2014 | 06:46 PM
tektrans's Avatar
tektrans
1-thermostat in upsidedown or bad?
2-air pocket?
First I would get the nose up by driving up on a set of ramps then run her and fill radiator. If that doesnt work then check the thermostat.
Old Jun 2, 2014 | 07:03 PM
DUB's Avatar
DUB
Lower radiator hose should have a wire inside it to keep it from collapsing.
DUB
Old Jun 2, 2014 | 07:11 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
2-air pocket?
Also turn on the heater and make sure it is blowing hot air while you have it on the ramps.....sometimes it takes 20 minutes to "burp" all the air out of the coolant passages.
Double check the fan clutch while the car is idling to make sure the fan is turning fast.....BE CAREFUL IF YOU TRY TO TEST THE FAN CLUTCH......a folded piece of long cardboard slowly pressed against the fan blades should NOT STOP the blades from turning fast...if it does, the fan clutch is going bad
Old Jun 2, 2014 | 07:15 PM
Mike Ward's Avatar
Mike Ward
Is the chin spoiler in place?
Old Jun 2, 2014 | 07:24 PM
70ZZ3 96LT4's Avatar
70ZZ3 96LT4
Default timing a 1981
Was your timing set with the distributor vacuum advance canister disconnected and the vacuum line plugged?
Is your vacuum advance operational?
Are you using full time vacuum advance, straight from the carb to the vacuum advance and using a full time vacuum source at the carb?
Old Jun 2, 2014 | 07:27 PM
brando1118's Avatar
brando1118
It's timing. You are most likely at a part throttle cruise on the highway. So there is still vacuum advancing the timing. Retarded timing will over heat the engine quickly, too much advance will do it very slowly usually assisted by detonation. Can you hear any pinging? Try retarding the timing a few degrees and see if you still over heat on the highway.
Good Luck!
Old Jun 2, 2014 | 07:39 PM
charleyahrens
Yes, it is.
Old Jun 2, 2014 | 07:41 PM
charleyahrens
2-air pocket?
I will try & let you know the results.
Old Jun 2, 2014 | 07:43 PM
charleyahrens
There is no vacuum advance on this distributor, shoud I check somewhere else?
Old Jun 2, 2014 | 07:47 PM
charleyahrens
The heater seems to function correctly. I used a cardboard tube from a roll of paper towels to test the fan clutch. It did not stop the fan.
Old Jun 2, 2014 | 07:48 PM
charleyahrens
Good Luck!
I do not hear any pinging or detonation. I will check the timing again.
Old Jun 2, 2014 | 07:52 PM
charleyahrens
The top hose is 1 year old. I will check the bottom hose when the engine is cold. I am not sure that it has been replaced in the last 5 years which is the outer edge of my memory. Getting old sucks.
Old Jun 2, 2014 | 08:53 PM
Scottd's Avatar
Scottd
Is all the foam in place around the radiator? I know this is the most often quoted reason, but its also the most overlooked. My inserts were missing around the perimeter. I used to hit 220 on highways and it wouldnt cool down until it sat for a few hours. I replaced the foam with generic Home Depot insulation and I now sit at 190, she hits 205 in traffic, 195 highway.
Old Jun 2, 2014 | 09:19 PM
Tim81's Avatar
Tim81
My 81 had the same problem and it took awhile to figure out but it ended up being the fan clutch. Good Hunting
To Overheating on Freeway
Old Jun 2, 2014 | 09:32 PM
Kacyc3's Avatar
Kacyc3
got a link?
Old Jun 2, 2014 | 09:50 PM
Jeff_Keryk's Avatar
Jeff_Keryk
Generally speaking, at freeway speeds you should have sufficient airflow across radiator (I believe you said the stock pieces were there). Suspect radiator efficiency. Is your radiator old? Also, make sure your pump is up to snuff. I like Flow Kooler pumps...
Good luck.
Old Jun 2, 2014 | 10:04 PM
Peterbuilt's Avatar
Peterbuilt
A better test for the clutch fan is to start you car cold, let it run for two minutes and shut the car off and check the resistance to turn the fan.
Restart the car and run for ten minutes (up to normal operating temperature), shut it off and you should have MORE resistance to turn the fan.
Don't use a spacer, if your clutch is bad get a new one.
