I've got a mostly stock (has true duel exhaust without cats) 77, and am thinking about doing some upgrades. Jegs has some heads/manifold/cam kits for around $2,000.. I know I could spend twice that and get a whole new engine basically, but that's not really what I want to do. Would a kit like this be reasonable, or a waste of money? I'm young and inexperienced and really don't know a whole lot about what needs to go into something like this. Any tips help!
I followed the advice of other members.......I made a list of the most inexpensive upgrade "on up" to the most expensive upgrade....with a horsepower improvement next to each upgrade.
That chart made it easy for me to see how much $$$$$ could be spent to get the greatest horsepower increase.
You'd be surprised to know that the most expensive items/upgrades didn't provide the best H.P. increases....and as little as a 20 H.P. upgrade is very noticeable on a stock engine. If you combine 2 or three inexpensive upgrades, you really feel a H.P.(torque) difference on the street!!!!
I believe you will see the best power gains but replacing your heads and manifolds, and a cam swap.. you can find the stuff used for cheap for example I upgraded to side pipes on my 74 and have my entire true dual exhaust on Craigslist with two new polished mufflers welded in for $80. And I bought dart iron eagle heads with harland 1.6 roller rockers for 300. On Craigslist.
You want to find 58-64cc chamber heads with around 180cc runner size. This will boost your compression and give you more power.
Fyi stainless obx side pipes with headers and sweet thunder chambered exhaust mufflers cost under a grand together...
Hugie82: are the ports on the alum heads larger, or just lighter weight? Did I also see on another thread that the ports on aluminum heads are located higher up? So my Hooker header/sidepipes may not connect properly?
shop around a little jegs dose not have the best prices on parts .figure out what your compression will be with what heads .buy the cam last to work best with the parts you decide on .speed way parts has some good prices on heads and other parts you mite need .I also like competition products also.what transmission do you have ?
I figured up what parts were going to cost, possible machine shop labor, having it all put together and I opted to go with a crate motor for less money.
I'm installing the Edelbrock RPM Airgap kit on mine. Give me a couple weeks to finish it all up and I can get you some real dyno numbers. I'm curious myself to see if its worth it!
An airgap intake with no other mods? you'll be lucky if you see a 10hp increase.... The factory intake was not the limiting factor...and the air space under the carb only keeps things cooler in the carb for the 10-15 minutes it takes for everything to come up to temp, then it performs just like the performer rpm. (this can have an advantage if you trailer it to the drag strip and start it up right before your run)
aluminum heads allow higher compression while still using pump gas.... thats the only advantage... if your sticking 64cc heads on an l48 with dished pistons than cheaper iron heads will actually have the advantage of being stronger and allowing uncoated steel shim gaskets as well as better cost.... for about $1,000 you can bolt on an extra 100-150hp.... that is if you have the confidence to unbolt the old stuff and bolt on the new stuff following directions from a repair manual on torque sequence and such...people really like to make it seem more difficult than it is here... Go to any other car enthusiast forum and youll be told its not rocket science...
Not just the intake.... 'kit' as in the Power Package with the cam and heads...
I see... well the rpm airgap is particular style of intake manifold because of the dead airspace under the carb to keep the float bowls and fuel cooler....
I wonder if you mean the "performer rpm performance package?" in any case you should see some real improvements over stock. as long as you also did away with the restrictive factory exhaust?
Have you done, or had done, any tuning to the engine? You might be surpeised what a good tune up can do. Tweak the carb, recurve the ignition, it makes a big difference.
