It's just my opinion, but those 882 heads aren't helping you much. As for your quoted 9.1 compression, Did you actually cc and measure everything to verify that? Many years ago I had a set of 882's with flat top pistons and did all the cc'ing and actually came up with 7.9:1 static compression ratio. Like the other guys are telling you, the 882's serve a good purpose as a boat anchor.
First off I want to thank you all for the replys What I discovered (and now I remember) last summer in an attempt to save fuel, I changed the vac. sec. to a heavier spring. I forgot all about it til today. I put the light spring back in this morning. I,ll go for a spin later today and see what happens. Wish I remembered that yesterday. My trip to the dyno was a waste. Its tuff getten old.
I'd say the results are dead on for the combo of parts.. A little tuning may net you another 20hp but... For that combo, I'd say its about right.
Smogger heads, tiny cam, no compression, spinning a heavy T400 and probably full accessories/clutch fan etc etc.. Pretty much all it's gonna do until you upgrade it.. You have enough steam to run 14.90s as it sits.
WOO HOO I,ll tell everyone I can run mid 14s
I,ll start shopping for heads. When winter sets in, I,ll have somthing to chase the blues away. (after deer season)
Thanks guys
I know, you can't really compare the numbers from an engine dyno and a chassis dyno, but you can compare the shape of the curve. I think a better set of heads will let your engine continue producing power into the upper rpms. Go aluminum.
