Plugs fouled
Old Jun 7, 2014 | 02:59 PM
SCHOONS's Avatar
SCHOONS
Default Plugs fouled
Now my other car is running like crap
Pulled plugs all black and wet with gas.
Missing and when I try to up rpms it backfires
Could this be from a bad Holley power valve?
Old Jun 7, 2014 | 04:02 PM
zwede's Avatar
zwede
Maybe but unlikely. More likely a stuck needle & seat.
Old Jun 7, 2014 | 08:59 PM
sgtwallydog's Avatar
sgtwallydog
timing sounds off. check the distributer
Old Jun 7, 2014 | 10:31 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Check all of the above......let us know what solved the problem.
(My Holley power-valve was ........"blowed up, Sir!"....and caused similar problems)
Old Jun 8, 2014 | 10:55 AM
SCHOONS's Avatar
SCHOONS
I am hoping it is one of the above.
If it turns out to be something else out comes the credit card again.
Anyway now power valve is in and so are the new plugs.
The distributor is a one year old MSD with a 6Abox.
I think I will pull the cap off the distributor first and take a look before I start it up.
Wish me luck
Old Jun 8, 2014 | 11:25 AM
bluedawg's Avatar
bluedawg
To check the power valves screw the idle mixture screws in if the engine dies there good if it doesn't then there bad.
Old Jun 8, 2014 | 11:59 AM
SCHOONS's Avatar
SCHOONS
Wish I knew that before I bought the new one.
Anyway I hope I don't wipe out all the new plugs when I start it up.
Was major pain putting the last 3 in
Old Jun 8, 2014 | 12:46 PM
doorgunner's Avatar
doorgunner
Be advised that you may get worse mpg using the power valve delete-"plug".......ask me how I know...LOL.
A bottle of Lucas Fuel Treatment in a tank 1/2 full of gas will clean up sooty spark plugs!
Old Jun 14, 2014 | 03:13 PM
SCHOONS's Avatar
SCHOONS
Problem solved
2 things were screwed up
First one was a bad power valve in the holley
Second one was a plug wire touching a throttle lever and grounding out
Car runs great now
Thanks for the input
Old Jun 14, 2014 | 03:46 PM
FireballXL5's Avatar
FireballXL5
Success! ;-) good job buddy!
To Plugs fouled
