If you do something like that, you should upgrade to a larger gauge wire WITH some type of fuse in'line to keep the car from burning up (or down) if an electrical problem occurs.
The 1980 Corvettes are run like that from the factory. A separate wire runs from the alternator and along the drivers side frame rail, then up in to the battery compartment to a small junction block. Then from the junction block to the battery terminal.
When I changed over to a CS144 alternator I replaced the alternator charge wire with a larger 4 gauge wire then removed the junction block and installed a "mega fuse" in it's place.
So for instance my battery amp needle always stays around 5 just a little over the 0. I have to disconnect my battery after I park every time. like last night I forgot to disconnect and this afternoon battery died would this help in charging the battery and keep my light from dimming every time I get a red light. Just wondering cuz if it helps I will also try it any pics or info would be appreciated. I changed my alternator to a msd 120 amp and it didn't make a difference from stock one.
What he said. I too, have ran a larger wire, but the LS alternator puts out quite a bit more than stock 350 unit did. From the J-Block, I also ran a heavier gauge wiring for the blower motor wiring.
I have some questions relating to this post....
What is the purpose of the junction block?
Why is the wire between the +ve terminal & junction box smaller?
What amperage should that wire be? Is 50 amp ok?
