TH350 max HP
Old Jun 8, 2014 | 07:01 PM
caryb78's Avatar
caryb78
Default TH350 max HP
What is the max HP you could put to a TH350 and not tear it up.?
Old Jun 8, 2014 | 10:07 PM
76CSRvette's Avatar
76CSRvette
My uncle has a 700 hp mud racer with a th350 says they can withstand a lot of hp depends on how you build them the th400 adds unwanted weight for him and he could make his th350 stronger and better for less than it would a th400. I'm using a th350 but I only have 370hp but built tranny to handle 600hp at least that's what I was told lol but they are reliable my car sat for 15 years tranny was still good I only rebuilt it cuz I sprung a leak in hose and replaced it with oil hose which burst in fw drove home like that messed up all gears. But it still gave me a few more trips after that.
Old Jun 9, 2014 | 01:25 AM
Haggisbash's Avatar
Haggisbash
Stock seems to be around 400hp??
This guy on the Chevelles forum seems to know his stuff - see below......
My TH350 builds:
5 clutch direct piston (piston machined for 1 additional clutch)
Sun gear bushings doubled up and lube holes drilled, de-burred.
NEW intermediate roller clutch (sprag) and hardened race. Race inside diameter specially prepped.
Direct clutches MUST be dual fed. This can be accomplished internally or by using a TransGo Kit. I do it both ways depending on application.
Valve body modifications to firm up shifts. Nothing fancy needed, and not too fimr on the 1-2 shift.
Heavier pressure regulator spring for increased pressure.
Governor modified for higher rpm shifting.
Pump machined for better sealing and pressure.
700-R4 low/reverse roller clutch and support.
Endplay setup on the tight end of spec,
Borg Warner or Alto Red plates.
Snap rings tack welded for high rpm applications.
That's about all you need on a TH350.
I have a couple running Reliably 10's in the 1/4 in ~3600 lb rides with nothing more than this.
The key is, not overly hard shifts from 1st to 2nd, proper sprag race prep, and dual feeding the directs.
really nothing fancy at all.
Old Jun 9, 2014 | 09:02 AM
gkull's Avatar
gkull
Are you talking about your original 78 tranny?
Old Jun 9, 2014 | 07:23 PM
caryb78's Avatar
caryb78
Default Th350
Yes Original trans, 21K miles on it, B&M shift kit.
Old Jun 9, 2014 | 09:08 PM
gkull's Avatar
gkull
It depends on how hard you are on it. if you are power braking or manually shifting with sticky tires. A shift kitted th350 will die with under 400 hp out of a 350 ci motor. I killed mine and had it hopped up to 550hp /500 tq level and it lasted a couple of years in a low 400 hp 7200 rpm 355 ci with slicks at the drag strip
Old Jun 9, 2014 | 09:12 PM
tektrans's Avatar
tektrans
I ran 9.6's all day long on my old th350. If you build it right it will hold up.
Stock....idk
Old Jun 9, 2014 | 10:57 PM
augiedoggy's Avatar
augiedoggy
th400 is heavier because it is a heavier duty early version of the th350.... The 400 is stronger as built stock. On the other forums there4 are guys running stock th400's with 600hp... both can be built to be better but as far as stock goes the 400 is stronger hands down. gm did the same with the 700r4 and 200r.... They test them in the field and then decide where to trim the fat to lighten them up and make them cheaper to manufacture. They also try to address the shortcomings of the predecessor.
To TH350 max HP
