Proud new owner of a 1981. My problem is with the front directionals. All bulbs work, but when I turn on the left or right directional both fronts flash. I checked with VOM the light blue and dark blue wires at the base of the steering column. I get the 12V reading on both whether left or right is on. Could the problem be the directional switch itself? Anyone have a write up on how to change out the switch in the column.
Do the rear turn signals flash in unison as well? Have you looked at the Hazard light circuit yet? Because that's what it's supposed to do. Finally, do you have a wiring diagram for your car?
the rears work fine left only and right only. it is just the fronts that both flash whether the right or left signal is on.
You might want to test the sockets up front before you tackle the directional switch,
Run a wire to a good ground and touch the other end of the wire to the bulb socket.
All bulbs and sockets work fine, the problem is that the front directionals do not seem to be wired seperately even though they are. That is why I tested voltage on both the left and right directional wires in the harness coming out of the steering column. If I turn on the left directional, both left and right front flash. If I turn on right directional both fronts flash. Rears are fine. That is why I suspect a problem in the column somewhere. such as the directional switch.
If you disconnect the harmonica connection and apply 12 volts to first "J" then "H" that might tell you if the problem is upfront or in the directional switch.
