1968 Tire size ??
Old Jun 10, 2014 | 12:21 PM
wdenkler's Avatar
wdenkler
7th Gear
Default 1968 Tire size ??
My neighbor just called and said he has 4 like new - P235/70R15 for sale...Will they fit on my 68?? I want to take off the Poly Firestone redlines and hopefully get rid of the grooved road drifting I am currently experiencing. Do Radials help stop this drifting?
Old Jun 10, 2014 | 01:32 PM
Revi's Avatar
Revi
Yes, they will fit. You may have a small amount of rubbing at full turn though.
Old Jun 10, 2014 | 10:25 PM
7T1vette's Avatar
7T1vette
You shouldn't have any rubbing with a 235-wide tire. But, the rims on a '68 were 7" wide; all other c3's had 8" wide rims. They will still work, but 235 ('G' series radial width) is about as wide as I would go with a 7" rim. Of course, you could always go to 8" rims...unless you need to keep it "original".
Old Jun 10, 2014 | 10:43 PM
68Thunder427's Avatar
68Thunder427
Depending on your ride height (see mine below) they may or may not fit on the front. The rear is no problem. I had to go with 215/ 70 R15 to be comfortable with the clearance.
To 1968 Tire size ??
