HEI setup challenges and solutions
Here is what I have in a 1980 C3
SBC 350, 8:5:1, Edelbrock performer heads, Weiand 142 blower and manifold, Holley 750 (4160) setup per lars. 700R4
Current dist is an ebay special with a hypertech coil.
Timing readings taken with innova 5568
Initial 16@700, 26@850 all in 48@4500, yes 48. This is AFTER replacing stiff springs with lightest ones in Mr Gasket kit 929G. So if I keep this I will have to restrict total mech advance for sure. I can add a stiff spring to get the top number down but that messes my target of 32@2800, and with the blower I want the insurance of no more than xx for total advance.
So is the ebay special good enough to tune and keep or is it smarter to get either a good stock HEI or pro form and curve it?
Since I have the blower I will be adding a BTM. I have the option of the programmable 6al-2 which allows me to control ignition timing. SO I could just lock out this dist and buy the MSD box, setup my timing map/maps via the laptop and call it good. I am leaning towards this. Lars used the BTM on his awesome 383 project but I have not heard from anyone on this forum who has used the 6al-s programable. IBANEZ 540 was looking at the same one and peaked my interest. Price is about the same so going with the 6al-2 might save me a few dollars in the long run. Just dont want to visit the dist issue later if this one is constructed of poor materials---plastic etc.
Then there is the topic of vacuum advance on a blown engine. Car is street driven and not WOT all the time so this does make sense or at least a timing map that can mimic it?
Let the comments fly.
Scott
Scott
16@700
16@850
rises at round 1100
28@2700
36@4500
did not run it up past 45k,
no obvious binding in the plates, so my guess is heavy weights with lousy machining which gave odd results. The tighter springs cinch things up more and allow for more linear movement? Sounds good anyway
for now this curve is barely acceptable until I limit it which will be a little bit of a pain but not too bad. At that point I will go one step lighter on springs, check timing, drive it around and check timing behavior a few more times to ensure a consistent result. If it provides it then great if not then to the bin with the ebay dist.
