Cam selection
Old Jun 19, 2014 | 07:30 PM
johnt365's Avatar
johnt365
I used the following calculator. You can use it to get the measurements you need and then try different cam grinds to see how it changes your dynamic compression.
https://www.uempistons.com/index.php...tors&type=comp
To get the cylinder head volume - you can try to find a part number on the head and look up the specs or take it to a machine shop and they can "cc" the head to measure it with fluid.
Piston head volume - hope you can see a part number on the piston. the piston design will help by seeing of it has 4 or 2 valve reliefs and if it is dished, flat topped or domed.
Gasket thickness and bore - this will be advertised on the gasket specs and can be a flexible area in the build.
Deck clearance - this is where you bring the piston to TDC and measure the distance from the piston to the top of the block with feeler gauges.
Cylinder bore is 4.030 for yours.
Stroke and Rods are determined by the engine size for the most part. 3.48 and 5.7 in for a 350
Old Jun 19, 2014 | 10:46 PM
augiedoggy's Avatar
augiedoggy
I found that my speed pro pistons advertised relief CC s were off a bit when I measured them with a syring and water... so we're my dart iron eagle heads...it appears they advertise them to be smaller than they are by a slight bit in some cases... (error on the conservative side) I used clear packing tape over the heads and poked a tiny hole and filled them with liquid until the air was all displaced and a flat straight edge was across the opening/ tape...
My block isn't decked so I just used the thin felpro 1094 shim gaskets to compensate and still have a good quench... no one has yet explained to me why this won't work just as well as long as my pistons are all in the hole the same amount although people often say there's a difference I don't understand how.
Old Jun 19, 2014 | 11:14 PM
REELAV8R's Avatar
REELAV8R
Originally Posted by Killingsworth 73
OK. I need to pull the drivers side head anyways (bad head gasket). Is there a thread how to actually do this? Which measurements I need to take and how?
http://forums.corvetteforum.com/c3-t...er-size-2.html
Post 31 will show you how. The more accurate you are the more you can narrow in on the proper cam for your application.
Put a spark plug in the head and do the same with the head chamber to get it's volume
Old Jun 20, 2014 | 06:05 AM
davidchristopher's Avatar
davidchristopher
Originally Posted by qwank
Don't be poking fun at Mako, he knows his ****
Hmm. I was being sincere. I'm choosing a cam myself. Leaning towards the 260H actually.
Old Jun 20, 2014 | 09:31 AM
bluedawg's Avatar
bluedawg
I don't think he was.
Old Jun 25, 2014 | 04:20 PM
Killingsworth 73's Avatar
Killingsworth 73
I've been told that someone with some good SBC knowledge and a scope can look in a spark plug hole and possibly identify what pistons I have, and find the casting # for my heads. Truth?
Old Jun 26, 2014 | 05:52 AM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
on Cam selection, keep in mind for the corvette the majority of your acc. run off of vacuum,
an aggressive cam will leave you, with very little vacuum to run your HEAT/AC,lights, wipers and such,
when choosing a cam, default to the milder selection, to keep your vacuum acc. working properly. good luck !
