Cant get the new motor going!
Old Jun 19, 2014 | 10:41 AM
sargas3's Avatar
sargas3
Default Cant get the new motor going!
Hi All,
This is my first post. I traded a motorcycle and so riffles last fall for a 81 corvette. The motor and trans had been pulled and owner had a brand new create 383 stoker pulse all the original parts. And all high performance edelbrock extras. I couldn't pass it up. So I got a shop manual and started putting the motor and trans together. I finally got it in the car a month ago. This is the first motor I have ever done and i'm not the most savvy with it come to this but I always wanted a C3 corvette. However it wont start.
The car cranks and gets gas but backfires or shoots gas out the carb. After asking around it sounds like when I set the distributor (vacuum not electric) in I might have it 180 off. So I turned it around same result. So I figured maybe my balancer is off and got a piston stop tool. lined it all up and tried again. (FYI the piston stop gave me different tdc than the actually timing make.) Same result. I have spark and fuel but it feels like there not firing right. And im at a loss now. Please give me any suggestions you might have.
Old Jun 19, 2014 | 10:49 AM
chvet73's Avatar
chvet73
Sounds to me that when the timing chain was installed the marks were not lined up properly.
Old Jun 19, 2014 | 10:51 AM
Jig A Low's Avatar
Jig A Low
just using the TDC tool doesn't insure you are TDC on the compression stroke. you need top make sure that part is right before you try to install the dist.
also, are you using a non-computer carb (I hope so), as the computer carb for that car won't run very well without the electronic dist. in place.
you may be better off to find someone local to you and see if you can get some "hands on" help with it.
Old Jun 19, 2014 | 11:04 AM
sargas3's Avatar
sargas3
Thanks for the fast responses. The chain was installed by the engine company that shipped the motor so I don't know for sure but I hope it was because that's not something I know anything about. The Carb is an 1411 I think. The 750 CFM electric choke (haven hooked that up was told I didn't need to). I wish I had a gear head friend that lived here. My buddy that has been helping me by phone is in Atlanta. I am thinking of paying his air fair at this point. I've had super bad luck with local shops. But if I don't get it soon I wont have a choice.
Old Jun 19, 2014 | 11:20 AM
Jig A Low's Avatar
Jig A Low
if you tell us where your at, there may be someone on here who lives nearby and can help you out, baring that.
lets make some assumptions for a minute, it's a new motor so MAYBE it was assembled correctly, that said, pull the #1 spark plug, put your finger over the plug hole and bump the motor over a little at a time, you should feel pressure trying to escape from the cylinder when the motor is on the compression stroke for that cylinder, once you start feeling the pressure, you should be able to align the timing mark on the balancer with your timing tab (mark dead on 0*), then you can look at your dist, the rotor should be pointing towards the number 1 cylinder (more or less), when you install your dist. cap, the spark tower that is aligned with the rotor tip will become the #1 spark plug wire, then base everything off of that using the normal SBC firing order.
Old Jun 19, 2014 | 11:26 AM
sargas3's Avatar
sargas3
I will give that a shot again. To be honest when I try that I don't feel the pressure. I cant really get my fat fingers to cover the hole. lol. I live in Madison heights Michigan. It outside of the Detroit about 15 miles north. If anyone wants to come buy I'm more than happy to get some help. Beers on me!
Old Jun 19, 2014 | 11:33 AM
Jig A Low's Avatar
Jig A Low
do you know if the engine was bought as a "long block" (heads and valve train installed) or as a "short block"? if whoever put the engine together didn't adjust the valve train correctly and got them too tight, you may never feel pressure. you really need to get something in there and see if the pressure is there, maybe get someone with smaller fingers or rent/borrow a compression gauge from a parts store. you HAVE to find TDC on the compression stroke before you can do anything with the DIST.
Old Jun 19, 2014 | 11:37 AM
sargas3's Avatar
sargas3
It was a short block. The head were still in the boxes when I got it. I installed them by the book but like I said I have never done this before so its very possible I made a mistake somewhere. I will get the compression tester today on the way home from work and see what's going on there.
Old Jun 19, 2014 | 12:18 PM
bruiser's Avatar
bruiser
St. Jude Donor '15
I could help you tomorrow if you can't get it going today.
Old Jun 19, 2014 | 12:22 PM
sargas3's Avatar
sargas3
Really! that would be great! I will post after work what happens with the compression test. Thank you! Seriously drinks of choice on me!
Old Jun 19, 2014 | 01:40 PM
hugie82's Avatar
hugie82
To narrow down what is going on, I would advise a compression test. This will let us know 2 things.
1) that you have good compression, your valves aren't too tight and the timing chain was installed correctly.
2) if all checks out, you can direct your attention back to the distributor. Firing order, 12volts producing a spark, timing marks set correctly and then timing is set correctly.
Many things can cause your problem! the good news is it just means something is off and can be fixed easily and cheaply
Old Jun 19, 2014 | 02:12 PM
sargas3's Avatar
sargas3
Thanks I will up date my progress in a few hours. I think I'm going to cut out early just to get some work done on the vette. Called the Oreillys by home and they have the tester.
Old Jun 19, 2014 | 02:29 PM
Amorget's Avatar
Amorget
One thing I've seen before is the rocker arms being overtightened. Did you make sure to follow the proper sequence when tightening them?
Old Jun 19, 2014 | 02:43 PM
qwank's Avatar
qwank
is this a roller cam or flat tappet? with all the cranking you've done you might have other problems once you finally get it started if it's flat tappet.
Old Jun 19, 2014 | 02:54 PM
sargas3's Avatar
sargas3
Went with rollers on the recommendation of my friend.
Old Jun 19, 2014 | 02:56 PM
sargas3's Avatar
sargas3
Yes because I don't know what I'm doing I went by the book literally. I mean its possible I messed up but I followed the instructions and asked a lot of questions before I did it. so (fingers crossed) I think I got it right.
Old Jun 19, 2014 | 03:20 PM
Camivette's Avatar
Camivette
I wouldn't do compression testing yet on a new engine. Lot of strain before breaking in the cam.
To Cant get the new motor going!
Old Jun 19, 2014 | 03:21 PM
Camivette's Avatar
Camivette
Roller ROCKERS or Roller CAM?
Old Jun 19, 2014 | 03:40 PM
qwank's Avatar
qwank
Old Jun 19, 2014 | 03:54 PM
scottyp99's Avatar
scottyp99
If it's a roller cam with roller lifters, the break-in shouldn't matter. Still waiting for that info, though.
Scott
