Heavy duty upper A Arms
Old Jun 23, 2014 | 06:04 PM
Haggisbash's Avatar
Haggisbash
Default Heavy duty upper A Arms
Could someone who has fitted these advise on how successful the increase in positive caster was in improving the straight ahead driving of their vette?
Old Jun 23, 2014 | 07:05 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
The trade off is that while increasing caster will increase straightline stability, doing so will reduce responsiveness. IMCO one should only do this if you have power steering and/or aren't chasing down every last ounce of handling performance. My $.02
TSW
Old Jun 23, 2014 | 07:31 PM
zwede's Avatar
zwede
I like them. I found the power steering to be over boosted. More caster returns some road feel.
Old Jun 24, 2014 | 12:30 AM
Haggisbash's Avatar
Haggisbash
Thanks guys, it looks like these will make it to the shopping list when the budget allows, I find the steering a little over responsive when travelling straight ahead. I added a shim to the PS pump to decrease the pressure slightly to give the steering more weight which helped. R&P would be nice but not compliant to use here and or very expensive to get compliance:-(. I believe I can live with a little less responsiveness for the way I use the car FWIW the car seems to have almost no self centering action in the steering at present.
Old Jun 24, 2014 | 12:50 AM
Günther-C3's Avatar
Günther-C3
Can you give me an internet-link to these upper a-arms?
Thanks, Günther
Old Jun 24, 2014 | 04:59 AM
Haggisbash's Avatar
Haggisbash
Sorry Gunther, I got the info from Corvette Americas paper catalogue but I'm sure a search of their site will turn them up!
Old Jun 24, 2014 | 08:08 AM
zwede's Avatar
zwede
Aluminum a-arms from Speed Direct:
http://cmc.speeddirect.com/itemdesc....-87416&eq=&Tp=
Steel from VBP:
http://www.vbandp.com/index.php?page...mart&Itemid=80
Old Jun 24, 2014 | 09:19 AM
Kid Vette's Avatar
Kid Vette
More here:
Global West Suspension Components
and here:
ridetech coilover system
Old Jun 25, 2014 | 05:41 PM
TheSkunkWorks
Just to follow up...
Note that the Speed Direct aluminum a-arms will also increase front camber gain, which means less static camber is required. Further, they have caster adjustment slots, so only camber requires shims.
FWIW, given that power steering systems somewhat mask true feedback, the apparent effect of improved feel had by dialing in additional caster is more a result of increasing the steering effort. Manual steering here, but whatever floats your particular boat is what you should go for.
OK, I guess that's $.04 now.
Old Jun 25, 2014 | 06:23 PM
Haggisbash's Avatar
Haggisbash
Mmm Speed Direct look nice but way too spendy by the time they were landed here:-( I have to go with something that looks fairly stock so that the compliance police don't pick it up here or you can be ordered off the road. Each compliance certification costs $700.00
To Heavy duty upper A Arms
