How much timing?
Bored.. 30 over
Keith black flat top pistons
Blue Racer Crane Cam WG-1173
• .050 Duration: 224° Intake; 234° Exhaust
• Advertised Duration: 298° Intake; 304° Exhaust
• Cam Lift: .290 Intake; .300 Exhaust
• Valve Lift: .465 Intake; .488 Exhaust
• Lobe Center: 107° Intake; 117° Exhaust
Polished and ported original heads
Super comp full length headers
2 1/2 exhaust
Flowmaster delta 40's
New dizzy, wires, plugs
Rebuilt & modified quadrajet E4ME
Currently have the timing at 12*
With the cam and additional stuff on here can I increase the timing for any more performance? Anyone have something similar that has advanced the timing to maybe 14 or 16?
slowly getting this thing running like I feel it should. Yesterday adjusted the spring fire the secondaries opening rate, maybe tonight I can warm it up and get the dwell dialed in... So close
Keep bumping the timing up until it pings under a light load and then back off until it stops. Keep a record of your changes, air temp, engine temp and gas used.
Bored.. 30 over
2 1/2 exhaust
1) disconnect my 4 wire adapter from the dizzy
2) using a tape, measure the balancer, then mark my balance at 36* clockwise from the timing mark already engraved on the surface. This would give me my 36* total timing mark
3) set my initial timing (currently 12*)
4) get engine revving to 2500-3000 ram or until the timing mark no longer advances. This would be the limit of centrifugal advance.
5) adjust dizzy until the 36* mask lines up with the "0" on the timing mark indicator. When at the limit of centrifugal advance.
(this would put me at 36* total timing, all in
6) verify timing is at factory spec (or my 12* as set now) when the engine is at idle
7) reattach the wire for the dizzy, test drive and listen for pinging. Any pinging, reduce timing by 2* until is gone
8)verify idle and dwell and call it a day?
I guess I'm asking if the computer controlled dizzy will handle the 36* total timing when all in without damaging the engine?
I read the article as well as all the papers mentioned in it. Each paper deals with vacuum advanced dizzys. Would the same hold true for my 1981 dizzy? Is computer controlled so I'm wondering if the setup would be the same. After reading this article I believe this would be the correct way to set it up :
Scott
Scott
Bored.. 30 over
2 1/2 exhaust
Lars
81 corvette test run - YouTube
I hope this explanation is clear. I do not have a lot of experience with computer controlled timing but I do know timing curves and advance theory. If you are above 54 one or more of the three timing circuits needs limiting or adjustment.
EDIT:As Lars said when I was slowly typing with no vacuum can the vac or computer adjustment would be with a chip. You can adjust mech advance speed, not amount, with lighter springs to get "all in" @ 2500-3000.
Ping minus 2 degrees should get it real close to where you need to be.
Use the fuel grade you plan to run regularly.
Advance it distributor till it pings slightly under load back off 2 degrees.
Do not drive in advanced condition too long as ping is pre detonation and no good for engine.
Until you can get it on the right electronic monitor this will work
Marshal
If I recall my initial with dizzy unplugged was 14*, subtracted from all in 36* gives me 22*
Plugged in I was reading 38* +- subtracted the 14* initial reading unplugged gives me 24*.
initial 14 + mechanical 22 + computer 24. Gives me 60. did I do this right? So I need to retard the timing?
The motor has a lot of work done to it and the butt dyno would work best unless you had a real dyno. With your advance being mapped by the ECU you're stuck with that unless you buy the Hypertec chip.
The only other choice is scrap the 81 dizzy and use old school hei.
Keep bumping it up until it cranks hard or pings. Then back off. You can feel it if it's running better or worse. It's that simple.
I certainly don't hear any pinging so you can go a few more degrees + on the timing
