454 over heating problem
Old Oct 1, 2015 | 12:43 AM
  #41
hwcoop's Avatar
hwcoop
Get a new radiator.... Odds are, the stock radiator is shot.... Even boiling/rodding them out doesn't always work...(didn't for me)... I tried all the tricks and I still couldn't keep it under 205* on the highway.... Then I slapped a Dewitts radiator in it and it dropped to 170* on a 90* day...
I dropped in a Dewitts, no more cooling problem, also noticed when i bumped my timing to 16BTDC temps dropped a bit
I run 50/50 antifreeze, 180 thermostat, fan shroud with seals, air dam and flex fan. long hiway drive temp gauge will stay below centre
Old Oct 1, 2015 | 03:11 PM
  #42
bashcraft's Avatar
bashcraft
Originally Posted by woodlawnmill
Having owned a '70 non A/C auto coupe and now a '72 L-48 converted to LS-5 all GM, I now conclude that a BB C-3 is loaded with overheating problems. Even if everything is PERFECT as to air dams ,timing, radiator,seals etc. You WILL have overheating problems. If I could have a do over I'd give up on the wow!,cool! factor of the BB and go with the SB hands down. Chasing bad engineering by GM does get really old and exspensive. Have a look at BB problems on this forum, most are overheating problems. See?
SW
All of the big block c3's running around with absolutely no overheating problems kinda makes your "conclusions" sound like a bunch of crap, now doesn't it?
Old Oct 2, 2015 | 01:48 AM
  #43
SteveG75's Avatar
SteveG75
Originally Posted by LS4 PILOT
The special rubber section that was added to the plastic spoiler from factory in 73 and 74 454ACcarsreally really makes a difference at speed.
I don't think there is a repro of that special piece...but the AIM has a page showing how it was installed . You can buy some material and make one up .
My 496 in the '75 would always run a little hot on the highway. Would warm up till my electric fans (dual Spals) would kick in and then slowly cool down. Wilcox is making the spoiler extension (listed for '79 L-82). For less than $70, solved all my problems.
The rest of my system is an Edelbrock water pump, March pulleys with the larger crank pulley for increased cooling, a Dewitt's radiator with the larger dual 1.25" cores, 180 thermostat, and the dual Spals controlled by my FAST EFI (195 on, 185 off).
The spoiler extension was the best improvement that I made. Used some double sided tape and rivits to install the extension with some 1" wide, 1/8" thick aluminum strips as a backer.
Old Oct 2, 2015 | 07:29 PM
  #44
woodlawnmill's Avatar
woodlawnmill
"bunch of crap"? I have tried to point out my problems in a strait forward way. Sorry to have upset you so. I should have been more clear. It's the interior temp regardless of engine temp that is the real problem. You may be correct in your views reflecting your own personal experience but it has not been even close to mine. I don't see many posts as to how cool and comfy BB's are as to driver comfort. It's quite the opposite. Mostly endless stories of battling TOO HOT interiors and engine temps. My '70 LS-5 AT 65K survivor non A/C driving back from the Sun Valley Natl. N.C.R.S. meet to Seattle some years back was a "Bake-A Thon" for sure at 80F weather. I would never have bought the car as driver/keeper if I knew then. Turn it for a nice profit? sure. It was not a comfy driver. You may believe my "conclusions" are a"bunch of crap" but your opinions are yours and mine are mine.
SW
Old Oct 2, 2015 | 08:51 PM
  #45
ddawson's Avatar
ddawson
So my new 496 with Dewitts radiator and stock fan is working fine. 180F thermo.
Doesn't get any were near the 210 mark from light to light.
Old Oct 4, 2015 | 09:11 AM
  #46
LS4 PILOT's Avatar
LS4 PILOT
Didn't know any one was making that rivet on air damn extension piece again. about 20 years ago a guy was making a very poor piece or copy in his garage and selling them. The metal backing strips were cheap too , wrong size rivets. The rubber he used was too soft and deflected to much at speed to really help. The original GM material was strange .
I had the damn on my 79 L82 and now on my LS4 . It makes a diff. At speed ....effectively doubling the air thrown up in front of the radiator or the std. Plastic damn item.
The BB will run cool . There was also a special small filler section on the bottom of the shroud . Locks in place with one screw and tabs. It's very rare part. Most were lost off the LS4 cars, pitched , whatever .....but it's another one of those items that keeps the teMp in check.
Under 90 degree ambient my 454 will never go above 180-185 . It has to be crazy hot for my car to get over 190 . Like a 95 outside day in slow traffic.
If you get all the right stuff in place it will run within factory limits
