MSD 6AL2 programable questions.
Old Jun 28, 2014 | 08:20 PM
cagotzmann's Avatar
cagotzmann
Default MSD 6AL2 programable questions.
I am looking at using a MSD 6AL2 programable for my ZZ383.
I have 1 question for anyone that has done this for his C3.
MSD recommends a 1 BAR map sensor PN 23111 for naturally aspirated cars, yet this part is discontinued. I believe a stock GM map sensor (80-89 camaro) will also work if you remove the tabs in the connector. Are there any other options that just plug in, or other 1 BAR Maps sensors that are available ?
Thanks....
Old Jun 28, 2014 | 10:57 PM
dugsgms74's Avatar
dugsgms74
here you go
https://www.msdignition.com/forum/sh...ad.php?t=17154
Old Jun 29, 2014 | 12:19 AM
cagotzmann's Avatar
cagotzmann
Originally Posted by dugsgms74
Thanks after reading this I went to look at a MAP sensor from those years they look correct but they don't plug in as the link shows. A key in the connector is 90 degrees off and you would need to break the key off. Then of course not 100 % sure it will work. Might need to call MSD and see what they say ?
Thanks....
Old Jun 29, 2014 | 09:56 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Is there anything special about that 1 BAR MAP sensor? There's millions of GM MAP sensors in junkyard cars, along with the harness, that you can pick up for probably two bucks.
To MSD 6AL2 programable questions.
