73 engine date stamp confusion
Congrats on your purchase .
Doesn't really matter what anyone feels about it your purchase. Some are just busy bodies and Pitas and jerks .....
I can sense your excitement .
Dig in to your new hobby and have fun learning.
The windshield frame where the T joins is rotted out? Are you SURE the rest of the birdcage is intact?
The rocker channels are usually the FIRST to go - and if you've got water in the windshield frame, then you've got rot in other places too. Guaranteed. These cars leaked from the FACTORY- the rot you're describing warrants a much more detailed inspection- by pulling out the dash, kick panels, the access panels in the rear wheel wells and the windshield pillars.
At this point, I would care a LOT less about what motor is actually in the car, and worry a LOT more about the rust issues.
My windshield header was toast- I knew that. When I pulled the interior trim I found this:
My frame rails also had a little bit of rusty flakes on them. This is what lay beneath:
I'm now replacing the frame, and I'm about to get into replacing the rocker channels from the #1 mount to #3.
Now, my 73 is probably a bit of an extreme case, but it's still worthwhile to check your car out CRITICALLY and making it safe before you do anything else.
