Alignment and Borgeson curiosity
Old Jul 1, 2014 | 08:05 PM
irelandr's Avatar
irelandr
Default Alignment and Borgeson curiosity
OK this might seem strange but just wondered about some wheel alighnment questions. I installed the borgeson box and had my front end aligned to factory spec's and it is much better than before with stock power steering but being one to wonder what if... On line many people said use factory specs but on the borgeson sheet it recommends increasing caster to 3-4 degree, and looking around caster changes can make it feel light which is why they use less on manual steering or heaveier which is why they use more on power steering but then I thought could I try it and see what it felt like, problem, just had it aligned...
OK maybe not a problem because I found some specs for old corvettes that said if I add 1/32 shim to the back will increase cast 1/2 degree so to go from 2 to 3 degrees I could add 2/32 (1/16) and to go to 4 I would add 4/32 (1/8) shim.
Now the big question what else in the alignment will this change? Maybe tow but a tape measure will fix that, wahat about camber?? I saw several places that said caster changes do not change tire wear so what am I missing??
Old Jul 1, 2014 | 10:27 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
If you don't remove the same amount of shim from one end of each CA shaft that you add to the other end you will increase static camber.
Despite the current trend to dial in a good bit more caster than was originally designed into our cars back in the day to improve perceived feel had with power steering (which tends to mask genuine feedback), use caution when doing so. The larger is the difference of shims from one end of a CA to the other, the more likely you are to bend a shaft and induce binding stiction at the bushings, especially if you're not running rubber ones. Thus, many aftermarket CAs having additional caster already built in. Hope that helps.
Old Jul 1, 2014 | 10:36 PM
Roadster71's Avatar
Roadster71
Hopefully you will be able to get 3-4 degrees. I had my car aligned after my Borgeson install and could only get 2.5 max. I will probably change the upper control arms over the winter to ones that allow more caster.
Old Jul 4, 2014 | 12:48 PM
irelandr's Avatar
irelandr
So it for example I take a 2/32 from one end and move it to the other then I would be doing it right?
IF it does what I would want then go get it checked, if not put it back like it was and I am back to original setting?
Old Jul 4, 2014 | 02:28 PM
qwank's Avatar
qwank
I have the stock alignment specs and the car drives fine. I wouldn't worry about it too much
Old Jul 4, 2014 | 03:07 PM
irelandr's Avatar
irelandr
It does drive good and turns like never before so just wondered seems like a few went with the increased caster but most are just going with factory specs.
Old Jul 4, 2014 | 03:14 PM
zwede's Avatar
zwede
Try it and see if you like it. Just move one shim. I like caster and have mine at 4 dgr, but I have aftermarket control arms.
Old Jul 4, 2014 | 09:10 PM
TheSkunkWorks
1) Yes, if you want to make a 4/32 shim adjustment for caster move 2/32 from one end to the other. Take from the front and add to the rear to increase positive caster.
2) As zwede says, try it and see if you like the result. Easy to go back, but do bear in mind my earlier remarks regarding not having too much shim differential from one end to the other on a given CA.
Discaimer - Viewers with manual steering please don't mistake my comments as my recommending more caster for everyone.
Old Jul 4, 2014 | 10:55 PM
Roadster71's Avatar
Roadster71
Who's control arms did you use?
Old Jul 5, 2014 | 07:26 AM
zwede's Avatar
zwede
I have the aluminum arm from Speed Direct.
Old Jul 5, 2014 | 09:20 PM
irelandr's Avatar
irelandr
Mine are factory but all rebuilt, been looking at a few others like VBP or global west but have not done anything yet spent this years allowance (and probably next years) on front and rear suspension and 700R4 transmission and Borgeson steering box.
To Alignment and Borgeson curiosity
