Spark Plugs Change; 1982
Jul 6, 2014 | 11:19 AM
Can you provide tips, photos, videos, or links to changing the spark plugs on a 1982?
Jul 6, 2014 | 01:06 PM
Jul 6, 2014 | 01:50 PM
FIRST thing to do is find drawings/diagrams (AIM, etc) of the engine/wiring assembly so that you know how it is supposed to be done.
After that, it's just dig in and be patient. Access can be gained from below and/or by removing the front wheels (where necessary).
Jul 6, 2014 | 02:59 PM
Do the front four plugs from up top and the back four plugs from underneath.
Jul 6, 2014 | 06:45 PM
Quote:
Originally Posted by
Priya
Jul 7, 2014 | 12:15 PM
Priya
I manage to do all from the top except for the back 2 on the passenger side.
Jul 7, 2014 | 12:56 PM
The rear plugs from underneath is the easiest access .
Plug wires are a pita but the ones that run under the engine mount you can pull the plug boot off and tape the new wire to it . Then pull it thru.
Jul 7, 2014 | 01:11 PM
Larry82
Hail Houdini!
