thermostat temp 68 vette
Old Jul 8, 2014 | 08:06 AM
greggome's Avatar
greggome
Default thermostat temp 68 vette
What thermostat should I use down in hot sunny Florida? The one that was in my 327/350 was a 160 degree unit my shop manual says 195 degree.
Old Jul 8, 2014 | 08:16 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
195 was stock.
Old Jul 8, 2014 | 09:34 AM
7T1vette's Avatar
7T1vette
Install a 180* stat and move the vacuum advance vacuum line to a 'manifold' vacuum fitting on the carb. Hooking the vacuum adv. can up to a 'ported' vacuum fitting causes the engine to run hotter at idle for better burning of hydrocarbons. That's the ONLY purpose of installing a 195* thermostat.
Old Jul 8, 2014 | 12:58 PM
LB66383's Avatar
LB66383
To thermostat temp 68 vette
