77 Window Motor ID?
I have seen the info on how to install it. It looks like a rebuilt motor and clean. Problem is I read about the L R turn around in these motors where the driver's side should be marked R even though the door it "L" This one is marked "L" but might it be right anyway for driver's door?
Also can someone verify if the connector is right, read there was a change in that too.
I see your confusion. Just open it up and check it out. See if it sits in right place before removing actual motor
