1981 2" exhaust heat riser valve
Old Jul 12, 2014 | 05:00 PM
maxmachz's Avatar
maxmachz
Default 1981 2" exhaust heat riser valve
Well I lost the damn thing somewhere. Took it off to modify it so it is open all the time, and lost it.
Can I get a spacer for it, or do I need another 2" valve assembly?
Any 2" valve, or 2" spacer and the flat gasket and donut ring?
Old Jul 12, 2014 | 05:18 PM
'75's Avatar
'75
Zip has one, pretty proud of it too!
http://www.zip-corvette.com/catalogs...=80+heat+riser
Old Jul 12, 2014 | 06:14 PM
maxmachz's Avatar
maxmachz
Yes, I know where to get the riser itself, but I would rather put a spacer in; like this;
http://www.parts123.com/parts123/yb....5Z50000050G~~~
no emissions testing in WI, has no impact on performance, it's for helping cold start up and emissions. I don't drive it in the cold!
Old Jul 12, 2014 | 07:51 PM
7T1vette's Avatar
7T1vette
$5 part at any junk yard...whether it works or not. Just use a grinder or Dremel to cut the rivets off on the valve plate. Leave the rest as-is. It looks the same on the outside.
It's a good idea to put the little 'block-off plates' in the intake manifold gaskets so the exhaust heat doesn't flow thru the intake runner, anymore.
Old Jul 12, 2014 | 08:29 PM
maxmachz's Avatar
maxmachz
How about this?
http://www.ebay.com/itm/67-68-69-70-71-72-Camaro-Chevelle-Corvette-Nova-Heat-riser-spacer-302-327-350-/330898283510?pt=Vintage_Car_Truck_Parts_Accessories&hash=item4d0b131bf6&vxp=mtr
To 1981 2" exhaust heat riser valve
