Which plugs?
Old Jul 13, 2014 | 02:28 PM
trk411's Avatar
trk411
Default Which plugs?
Hi all,
Ok, I have scoured the forum, but haven't found a lot of definitive info. I have a 1967 StringRay, but the engine is a 1968 427/400. I am looking at changing the plugs, but I'm not sure what to use. Currently, the car has Delco R44TS, but some of my searching suggests that these may not be the right ones. Can I run R44XLS or should I stick with the R44TS? Or do I consider a "43" series plug? Also, if I end up using a non-tapered plug, do I need to use the little metal gasket that comes with the plug? Sorry for all of the questions, but I just want to make sure I get this right! Just let me know if any other info is needed to answer my questions.
Thanks!
Old Jul 13, 2014 | 02:41 PM
hugie82's Avatar
hugie82
The stock plug 44TS should work fine. You can look up the cross over chart for other makes. For 20 years I've been hearing how champion plugs suck but I never had a problem. Accel, NGK and iridium plugs all work great but cost.
Crazy plugs like E3 I tried years ago and it wasn't worth it.
Old Jul 13, 2014 | 02:48 PM
Ironcross's Avatar
Ironcross
ALL....... BB 396 and 427`s use a 3/4 reach plug....like .AC # R45XLS. The R45TS is a small block plug....any parts store should carry them. And while on the subject, .035 is the correct gap too...
Old Jul 13, 2014 | 04:10 PM
trk411's Avatar
trk411
Thanks. So just to clarify, I should go with the XLS plug, correct? I am therefore assuming that the 44TS plugs were incorrect? Lastly, when installing new, non-tapered, plugs, do I need to use the metal gasket/washer on the plug? Thanks again!!
Old Jul 13, 2014 | 04:20 PM
jnb5101's Avatar
jnb5101
Autolite AR 3923 have a 5/8" hex rather than the 11/16" of the Delco's. Much easier to install, and operate well.
Old Jul 13, 2014 | 06:20 PM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
with Wally, AC R45 XLS is what I use on my 68 427/390. It's the right plug for your 400 horse also.
Old Jul 13, 2014 | 06:27 PM
trk411's Avatar
trk411
Great, thanks! Any idea what negative impacts could be caused by running the R44TS plugs that were already in it?
Old Jul 13, 2014 | 06:47 PM
capevettes's Avatar
capevettes
CF Community Team
2016 C2 of Year
No long term effects. It will just run better with the R45 XLS. It's the right heat range for a street driven Corvette. You will probably notice better throttle response throughout the RPM range
Old Jul 13, 2014 | 06:57 PM
Ironcross's Avatar
Ironcross
A few facts to help read plug information
R' is for resistor plugs
T' means used in tapered seat heads
S' is for extended electrode
Yes use the washer when installing the plug and head that requires them...and not all years are the same as the 454 engines do use a tattered seat plug correctly but not the 396/427`s
Old Jul 14, 2014 | 12:40 PM
trk411's Avatar
trk411
Thanks all! I picked up a set of R45xls today and hope to get them in soon. Again, I appreciate all of the help and knowledge!
To Which plugs?
