newbie help
Old Jul 25, 2002 | 06:23 AM
71newbie77's Avatar
71newbie77
1st Gear
Default newbie help
Hi all,
I just picked up two vettes recently. First is a 71' Convertible 454 4spd (99.9% sure its not the original motor, but looks like an 454 car) Second is a 77' L-82 Coupe 3spd. I've decided to get the 77' up and running first because it is in the best condition.
I've changed all the fluids in the car. What else should I do before I get the car on the road? I've heard that all old corvettes should have their brakes replaced. I looked at the calipers and they have a little bit of rust and they seem to be working ok. Should I still replace them?
Lastly,
1. the 71' 454 ...how do I determine what kind of 454(ie. 80s truck motor, etc) is in place and what kind of transmission is mated to it?
2. the 77' L-82 how do i determine which 3spd I have, they had two didn't they?.
Thanks a bunch,
Mike
[Modified by 71newbie77, 2:25 AM 7/25/2002]
Old Jul 25, 2002 | 06:33 AM
Zane's Avatar
Zane
Default Re: newbie help (71newbie77)
If your Vetts have been sitting for a wile I would check the fuel pumps for leaks. They might not leak at first. The rubber in them gets hard just sitting there. Then when you start using it again the rubber starts to brakeup and then starts leaking all over. Just a safety consern I'd keep your eye on it. ;)
Old Jul 25, 2002 | 09:53 AM
Edzred72's Avatar
Edzred72
Check all your hoses, fuel lines, trans lines, and belts for cracks. Squeeze them to make sure they are not brittle, and will crack/break under a load. Also check all the hose/fuel etc..connections. Once you fire that baby up...creep forward and use the brakes to see if they function properly. Shift the trans a couple times back and forth to check that too before you hit the road. Good luck and..... have fun!!!
Eddie
Old Jul 25, 2002 | 12:12 PM
Sting Raycin's Avatar
Sting Raycin
Default Re: newbie help (Silvr77)
Are you saying it has a 3sp manual?
In 77 only 4spd manuals were offered, there was a close ratio and a wide ratio. Also there was the TH-350 automatic
Old Jul 25, 2002 | 11:49 PM
LAvetteman's Avatar
LAvetteman
St. Jude Contributor
Default Re: newbie help (jdharkey)
Welcome, please register your 71 at: http://www.71corvette.com
To newbie help
