OK, so I've done my research and have been browsing over several threads for the past few days. I still cannot make a decision and it seems to really be back-and-forth on opinions.
Car is in the build phase and never been on the road, so I have nothing to compare too.
357 cu. in. (.040 over) Weiand 142 mini blower, TKO-600 trans. (.82), 3.36 rear gear (may change in the future). Leaning towards a 218 intake 230 exhaust @ .050 cam on a 113 lobe separation. Either 1 step smaller or larger, but you get the generally idea. 27" tire - 19 x 10.
Fun street car is the theme.
Would you do a lightweight wheel, or stick to something a little heavier?
IMO it's not needed. If it was a small 327 with all out race trim than I would do it. With a blower, you won't even notice a difference.
Sounds like a fun ride be cautious on the cam overlap with the blower. Too much may cause idle problems and backfires thru the huffer is not a good thing.
I'm not following... Are you saying to do something light?
I've seen 15lb, 18lb, 20-22lb, 25lb, 30+...
Reference the cam, been looking at comps nitrous cams and blower cams. Haven't looked too much at the others yet. The one I referenced is the nitrous NX262. You think the 12 degrees is too much? The NX256 is 212/222 @ .050. I should probably leave this to another thread, because cam selection is still up in the air.
From: Graceland in a Not Correctly Restored Stingray
Noting that I'm substantially more AX/RR oriented today than during my drag racing days gone by, over the years I've run progressively lighter flywheels behind a succession of fairly stout 427 BBs in my shark, with my favorite setup, so far, having been 15# (SFI, of course). It is with that experience in mind that IMCO heavy flywheels are best left to under-powered/over-tired cars and/or to those who either don't know or don't care to learn how to shift (up and down) with the proficiency required to take full advantage of having lower flywheel inertia. YMMV
Yes, do keep your LSA to the wider side not only for the backfire issue, but also so that you don't loose too much boost due to excess short-circuiting during overlap.
I guess that's where my hesitation was coming from.. It seemed like a lot in favor had some pretty big cu. in. built motors with some low gears. I know the blower will really help out, but wasn't sure how my smaller motor with taller gears would be.
Found a guy local that has this... (for a good price)
The blown pump-gas SB C3 I've driven certainly didn't need the extra momentum of a heavier flywheel.
FWIW, I think many people just don't put enough time and effort into adapting to the quicker RPM response time before they give up, but it does require more attention and precision to master. Oh, and I'm thinking it might be a good idea to think about a limiter.
That said, I haven't driven a lighter flywheel than that in a while. I didn't enjoy it the last time I did, but I was much less proficient at driving then...
Besides the power gain from a lightweight flywheel and pressure plate, it is pure fun to blip the throttle and have the rotating mass spin up right now! Just what you said you wanted - a fun street car.
Reason: add fun
My point being, you can install a little weight flywheel but if you were to compare the light weight flywheel to a stock steel. You most likely wouldn't feel the difference in the seat of your pants. It might be worth a tenth of a second in the 1/4. It all depends on budget and if you really care about that 10th of a second.
I agree. You do have to love the art of driving to do it though.
When I'm driving around in my Cayman S, downshifting is effortless as the motor is responsive and the clutch predictable.
I find my billet steel flywheel to be very responsive but still be more streetable like a heavy iron flywheel.
