Not a simple question to answer. Temperature and air moving across the condenser make a difference in gauge readings.
If you are planning on working on this when you do not know what you are doing...do yourself a favor and take it to someone who knows.
It is NOT as simple as putting more freon in it. Putting too much freon in if it is being changed will possible make it not work correctly.
DUB
For your concern. I do know what I am doing but I cannot access my service manual for the temp/press chart. Generally speaking the pressure at 75degreesF is a good avg.
A very simple answer is on an 80 degree day. With the compressor on you want to see around @40 psi on the low side. With the compressor off it should jump up to @80-90psi.
No worries. I ,obviously did not know that you know what you are doing. 'Some' people attempt to do this without proper knowledge and can get hurt or damage things...so I was erring on the side of caution.
