Blockhugger headers
Old Jul 25, 2002 | 02:08 PM
GR8T WYT's Avatar
GR8T WYT
Default Blockhugger headers
I have a 77 with 350 and AC. Has anyone installed Hooker blockhugger headers with this combo. I'm concerned with the fit near the evaporator box and the brake booster. Any other unforeseen problems would be appreciated. Looking to install true duels and 2.5" pipes. Jet Hot coating, any comments? Thanks, Bob
Old Jul 25, 2002 | 03:25 PM
e3pres's Avatar
e3pres
St. Jude Donor '08-'09
Default Re: Blockhugger headers (GR8T WYT)
I would go with the Dynomax Ceramic Coated units. They are full length. They're specifically designed for a C3. And, they're only $209! Most places want at least $150 just for the coating. I love mine.
BTW- They have great spark plug clearance.
Old Jul 25, 2002 | 03:44 PM
69 N.O.X. RATT's Avatar
69 N.O.X. RATT
From: Pettis Performance 565 with two stages of Nitrous Supply nitrous 1.082, 4.61 at 155, 7.17 at 192
Default Re: Blockhugger headers (e3pres)
I would agree, I have seen dyno reports that show block huggers are not as efficient as long tube headers
Old Jul 25, 2002 | 04:20 PM
GR8T WYT's Avatar
GR8T WYT
Thanks for the info, will give it consideration. My main reason for switching is for heat control in the cabin and engine compartment, not top end power.
Old Jul 25, 2002 | 04:25 PM
Fevre's Avatar
Fevre
Headers give off more heat than stock manifolds although I hear the ceramic coated ones are pretty close to the manifolds. Header wrap is an option but I don't like the look myself.
Old Jul 25, 2002 | 04:47 PM
Smokehouse69's Avatar
Smokehouse69
Cruise-In VI Veteran
Cruise-In VII Veteran
Ceramic coating makes a remarkable difference in temp control. A bubby of mine just put some on his 79 (Dynomax) and he says the heat reduction is tremendous. The headers are cool to the touch, 10 minutes after the car is shutdown. (No more heat thru the firewall and floor!, while just setting!)
Old Jul 25, 2002 | 04:49 PM
GR8T WYT's Avatar
GR8T WYT
Default Re: Blockhugger headers (Fevre)
Thanks Fevre, That's what I thought. I read on the web that header wrap will destroy your headers. I figured that blockhuggers being smaller than full size headers and coated to boot would give off less heat than full size headers or stock manifolds. Stock hold on to the heat for quite a while. Hooker calls them street rod headers, I'm guessing blockhuggers are the same thing. Bob
Old Jul 25, 2002 | 04:53 PM
GR8T WYT's Avatar
GR8T WYT
Default Re: Blockhugger headers (Smokehouse69)
Thanks Smokehouse, I've heard that too. Anyone out there running street rod(blockhuggers)/coated headers. I'd like to hear from you on this subject. Bob
Old Jul 25, 2002 | 04:59 PM
Fevre's Avatar
Fevre
Many guys hear run header wrap and I think as long as you don't get it wet or drive in the snow and salt with it, the headers will last a while. I have though about shortys and have tried to locate ones that would bolt right to the stock exhaust but have not got a definitive answer yet. I am going the dynomax route since I am going to build a 383 that need the headers to breath right. I believe there is some guys running block huger syle headers and will chime in in do time.
Old Jul 25, 2002 | 05:12 PM
GR8T WYT's Avatar
GR8T WYT
I,m like you, I don't like the look of wrap or fake stainless braid on radiator hoses either. Just my opinion. Shorty's use a collector/reducer setup and should be able to tie to your existing head pipes, cut off the stock donut setup and weld up.
To Blockhugger headers
