transmission question
Old Jul 26, 2014 | 01:24 PM
dklumpp's Avatar
dklumpp
Default transmission question
Hey guys just bought a 69 conv that was originally a 427 390hp with a 4 speed and now has a 454 with a Saginaw 4speed and a hurst shifter. The transmission leaks pretty bad I was thinking of converting it back to a Muncie m20 trans. My question is will I have to install a different shifter or can I get away with changing just the shift rods? Anything else I need to look out for? Will I need a different clutch setup? Any thoughts would be greatly appreciated. Also, If I keep the Saginaw the speedometer is not hooked up and it looks like the cable does not work on this trans. Would I need to change the speedometer gear and the cable input to make it work?
