As you can tell from the number of posts, I am new to the forum. I have enjoyed reading posts every night and have learned alot from everyone. Now I need your help with finding what engine I have.
I bought a 68 convt. with a big block. I know it is not a matching engine but I am not sure what I have in it. Here are my numbers:
front of block near pulleys: T0508TRL
near fire wall: big letters GM T14 then lower HO 5445 and a P next to them. the fire wall numbers are hard to decipher, the H could be just a box but it is hard to tell. there also is something in between the HO and the 5445 but it does not look like a letter or number. thanks for any help, Keith
Yes, I am positive that it is a big block. The numbers on the front of the engine are clear as day and I can see them well, it is only the numbers on the back that were tough. thanks for trying. :cry
Kieth; Don't have a clue on the rear #'s you've located. As far as the T0508TRL goes..........
T = Tonawanda assembly plant
05 = Month built (most likely May)
08 = Day of the month built
TRL = Is the engine code that denotes the type of engine.
I'm going to hazard to guess that the "TRL" is a code for a truck motor. All the codes for Corvette B.B. motors with three letter designators (70-74) start with a "C" I.E. CGW, CZU, CZN, Etc.
Of course if anyone knows for sure please call: :bs :nono:
