Hi all.
I'm hooking up a vacuum pump and reserve tank to make up for my lack of engine vacuum for my brakes in my 74. Can I, should I leave the engine vacuum hooked up in parallel whith the new system, or cap it off? Was thinking of leaving it hooked up in case pump fails. Going this route because when I checked vacuum I only had about 8 Hg. That was with all vacuum lines still tied in. Assuming the low vacuum is from modified engine, a 383. Done before me. Pump is primarily for brakes, but may hook in other vacuum loads, lights, climate control. I'll see how it works first with brakes. Guess I should try and see if I have any leaks in the system for lights, etc first though. Then same question, cap the engine vacuum from that system? Brake vacuum is from carb and lights from manifold.
Thanks Brent
I've never used a vacuum pump before, so I may be way off base here, but I would think that if your engine generates 8" of vacuum, and you have a vacuum pump that generates more that 8" of vacuum connected to the manifold, it will suck air/fuel from the manifold. That can't be good, right?
Scott
I would have a check valve , so it would suck from the engine.
Hmmm, didn't think of that. Might be a good idea. Like I said, I don't have any experience with vacuum pumps, so I really don't know what I'm talking about. Kind of interesting, though.
I would not assume your system is leak tite,
I would remove all lines to establish your true engine vacuum baseline pressure.
then make a desicision on what yo need to do.
evaluate the problem instead of just throwing equipment at the problem.
Well after I got the vacuum pump hooked still not holding vacuum. I removed all vacuum lines from carb/intake other than vacuum advance. At idle about 800rpm read 10Hg. As rpm increase so does vacuum. So started checking system for leaks as you suggested , after I spent money, probably a waste. Anyone want to buy a vacuum pump? Lights seem pretty good ,but the brake booster isn't holding vacuum. I think I can hear and feel the leak where it connects to the master cylinder. Replacing the booster is not a job im looking forward to. Should I replace the master cylinder as well? Guess I should have went with the hydro boost from the start. I learn the hard way.
Don't feel too bad, if it wasn't for the hard way, I wouldn't know anything!
Do not open your hydraulic brake system(master Cylinder)
if your brakes are working properly, that opens up more problems.(brake bleeding issues)
to properly test your vacuum components use a hand pump and pull vacuum on each component,
what ever reading you initially pump to say 12 inches.
your component should be able to maintain that vacuum reading for 1 minute, minimum.
if it does not , it is leaking.
a stock engine with everything vacuum disconnected, including power brakes, should be able to pull 12" of vacuum.
