Coilovers
Old Aug 1, 2014 | 12:08 PM
Kacyc3's Avatar
Kacyc3
Default Coilovers
would using something like these
http://www.summitracing.com/parts/ha...make/chevrolet
with
http://api.viglink.com/api/click?for...%26amp%3BTp%3D
work?
Old Aug 1, 2014 | 12:27 PM
ddawson's Avatar
ddawson
You would need different springs. Speed Direct provided me springs from http://www.bluecoilspring.com/
Old Aug 1, 2014 | 03:32 PM
Kacyc3's Avatar
Kacyc3
for spring rate, because the adapter in the bottom link should allow the use of that spring correct?
Old Aug 1, 2014 | 03:46 PM
ddawson's Avatar
ddawson
Correct, The BlueCoil Company matches the adapter and the Corvette Spring pocket.
It may be cheaper to just get them from Speed Direct. I also added an A-Arm reinforcement puck from VBP.
I just needed longer bolts and the whole install was super easy.
To Coilovers
