help with alternator problem
Old Aug 3, 2014 | 10:43 AM
Kacyc3's Avatar
Kacyc3
Default help with alternator problem
Last night the 2nd alternator in 2000 miles dropped to 12 volts on the gauge and with fans and headlights just over 9 volts. Last time I verified it with the voltage my ecm was seeing and double checked it when I returned it under warranty to the parts store, it was a new Remy . This time I drove it home from the track 100 miles away. By the time I made it home the gauge was showing about 9 volts with nothing no headlights or fans on, what could be killing these alternators?
Old Aug 4, 2014 | 12:51 PM
MelWff's Avatar
MelWff
Where are you buying the alternators ? If both from same place maybe you should try some place else. The Delco site does not show new alternators only rebuilt
http://parts-catalog.acdelco.com/cat...log_search.php
Old Aug 4, 2014 | 02:16 PM
BlackC3vette's Avatar
BlackC3vette
When the alternator is replaced multiple times and all your connections are good, maybe it's time to look at the battery. A clamp on type ammeter is require to check the total resistance of the battery. When an engine first starts up, the amp flow back to the battery is considerable, but after a short time, the amperage should be back down to about 8 to 10 amps. If the amperage is still up into the 20,30, 40 range, the battery has internal problems and the alternator continually putting out that amperage will be short lived. The clamp I have plugs into a regular digital voltmeter. If the amperage does settle down to that 8 amps at idle, then I would suspect the quality of the rebuilt alternators.
Old Aug 4, 2014 | 07:15 PM
Kacyc3's Avatar
Kacyc3
the battery was replaced last year, after looking at several pics i found online I believe the plug I grabbed from the salvage yard is wrong for the alternator.
Old Aug 4, 2014 | 10:57 PM
BlackC3vette
The young age of a battery does not guarantee it's performance.
Old Aug 4, 2014 | 11:46 PM
PeteZO6's Avatar
PeteZO6
Why don't you learn how the alternator operates so you can trouble shoot it, repair it and be on your way. They are actually pretty simple devices.
Mechanical parts include the rotor/shaft, slip,rings, brushes, bearings and case. Electrical parts are the rotor, stator, regulator and the diode trio.
A volt meter, ohm meter, circuit descriptions and diagrams, plus any replacement parts are all you need.
A few simple tests on the car following the Chevrolet Chassis Service Manual will help you determine where the problem is.
Save money and stay away from those crappy rebuilt, guaranteed forever parts.
Pete
Old Aug 5, 2014 | 12:26 AM
LS4 PILOT's Avatar
LS4 PILOT
I d take the battery back to auto store and have them do a test on it for dead cells.
Sounds like a defective cell in the battery
To help with alternator problem
