Clacking noise troubleshoot
Old May 18, 2015 | 01:53 AM
Nick81's Avatar
Nick81
Cruising
Originally Posted by Guyddog
So everything on the top end looked ok, nothing to give away the fact the valve was the problem? How long did it go before the valve broke?
The only thing on the top end that looked weird was the valve tip. It was slightly different from the rest (a little convex in shape with the concave indentation on the rocker arm). Other than that, it all looked normal.. I thought it might have been something small like an exhaust leak so I didn't let it prevent me from enjoying it. I drove it for about a month and a half only on weekends until it finally went.
Old May 18, 2015 | 09:39 PM
Guyddog's Avatar
Guyddog
Thanks, do you have any pictures of the seat that failed? so this was ok until you had the seals replaced then you heard the ticking? I have seen valves drop from worn keepers but yours were tight?
