383 suggestions-dyno
Old Aug 5, 2014 | 06:23 PM
Floatplanepilotguy's Avatar
Floatplanepilotguy
Cruising
Default 383 suggestions-dyno
Just had my 383 dyno completed, looking for your thoughts, 78 vette with 383, 230/230 cam 110 lobe. .480 lift, flat tappet cam, average aluminum heads, team g single plane, holley 750dp carb, pertronix flame thrower electronic ignition, 1 5/8" headman headers with 2.5 inch stainless steel true dual exhaust, turbo 350 with b@m 10" 3000 stall, shift kit and b@m transmission cooler with 3.55 gears, dyno was 375 rwhp and 370 torque, rwhp seems ok but torque numbers seem low, is the high stall robbing torque number, like to get over 400rwhp thinking afr 195cc eliminators and higher lifters will make cam seem bigger and flow better allowing 400 rwhp, what's would you do, thanks
Old Aug 5, 2014 | 06:43 PM
DucatiDon's Avatar
DucatiDon
C2 of Year Finalist (performance mods) 2019
2018 C2 of Year Finalist
Why didnt you put a roller cam in it? What compression are you running?
Headers are small for a 383....The auto will sap a bunch of power. What rpm was the peak number? Thats about 450tq at the crank which is pretty good for your mild build.
Old Aug 5, 2014 | 06:52 PM
LS4 PILOT's Avatar
LS4 PILOT
I kinda like that build....would be plenty for me
Old Aug 5, 2014 | 07:13 PM
C3 Stroker's Avatar
C3 Stroker
My former 383 had similar rwhp (373 hp), but over 400 rwtq, and I also have an auto trans 3000 stall. As DucatiDon asks, need to know peak rpm number.(Current heads?). That being said, 375 is a healthy horsepower number for such a mild cam.
On a chassis dyno it is very difficult to get a valid torque read with an auto trans. It takes a bit of driving "technique". The TQ converter multiplies torque like crazy when it "flashes", and the trans will downshift when you floor the pedal from a slow start. Then TQ numbers go haywire. I have found (coached by the dyno operator) that you must slowly drive to 3500 rpm, allowing the car to achieve high gear, then slowly (you have to feel for it) achieve full throttle without allowing the trans to downshift, then continue to your desired highest rpm. Even then, you will still see your TQ peak when the converter flashes, since you have a 3k converter.....and it's usually quite high if you have an efficient converter.
Old Aug 5, 2014 | 07:20 PM
cv67's Avatar
cv67
St. Jude Donor '05
Thats a decent # for what you got if you ask me esp with a flat tappet
Sure the AFRs will make a nice jump in power over most outof the box heads. tpi421Vette in the C4 tech section is a good go to guy for them.
Old Aug 5, 2014 | 08:54 PM
Floatplanepilotguy
Cruising
Max rpm is 5500 while I break in motor, electronic ignition shuts down at 5500 at break in, also timing is only at 34 degrees during break in, compression is at 10.4 to 1, just looking for a little more, should be satisfied it's a fast car but just want a little more, should I do different cam like a comp cam 294s and average heads or great heads like AFR and no cam change, or nitrous 100 shot, feel like nitrous is cheating, is 375 rwhp respectable
Old Aug 5, 2014 | 08:57 PM
Kacyc3's Avatar
Kacyc3
What do you mean average aluminium heads ? do you know anything about them?
Old Aug 5, 2014 | 09:02 PM
Floatplanepilotguy
Cruising
64cc 190cc, bought motor from friend, flow around 250ish .500 lift, Chinese head
Old Aug 5, 2014 | 09:27 PM
Kacyc3's Avatar
Kacyc3
those are better numbers than my l98 heads
Old Aug 5, 2014 | 10:32 PM
biscuitville's Avatar
biscuitville
FPG - I think you have pretty good numbers, especially considering you stopped at 5500. 1&5/8 headers are good for TQ and the 230 cam; may want to go bigger if you switch to a bigger cam to get more HP.
Before getting new parts, do you know what your quench is and have you port-matched your heads/intake?
Old Aug 5, 2014 | 10:39 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
That translates to about 500 RWHP. Very optimistic Dyno.
AFR 195 heads with 8019 springs and this cam and 1.6 rockers http://www.compcams.com/Company/CC/c...?csid=152&sb=2
Will get you a bunch more power across the board with identical drive characteristics and powerband.
Old Aug 6, 2014 | 07:39 AM
augiedoggy's Avatar
augiedoggy
procomps I'm guessing?
if you want more torque why not go to a dual plane intake? it should certainly deliver more torque on the street. IMHO single planes are great for WOT but second to a high rise dual plane in every other scenerio.... Especially in a heavy car. A dual plane will make it "feel" faster on the street but a single plane will show you quicker numbers on the strip...take your pick.
Old Aug 6, 2014 | 05:01 PM
Floatplanepilotguy
Cruising
I would say more like 450hp at crank, minus 20 percent loss equals 375 rwhp, I have spent a lot of $ on this car and i have couple more thousand to complete engine work, just want the best bang for buck with increasing hp and performance, afr heads are $1500 alone, what about profiler-jegs heads, they flow almost as good as the afr and I could increase to 1.6 rockers for the same price as the afr heads, augiedoogy I don't have the clearance under my hood for high rise dual plane,
Old Aug 6, 2014 | 05:41 PM
StraubTech's Avatar
StraubTech
Most SB heads need a duration split. Your torque is low because the engine is corked up with exhaust.
Old Aug 6, 2014 | 06:27 PM
Floatplanepilotguy
Cruising
So what 1 3/4 headers and 3" exhaust, or better flowing head, or both
Old Aug 6, 2014 | 09:47 PM
C3 Stroker's Avatar
C3 Stroker
Would be interesting to know peak rpm for TQ. My 383 had 373 rwhp also with 1 5/8" headers, 2 1/2" exhaust and stock mufflers. Mine had a 230/230 @ .050 hyd.roller cam and AFR 195s. However, peak rwtq was 456. This was at 4300 rpm, right where the converter flashes.
Old Aug 7, 2014 | 08:15 AM
StraubTech's Avatar
StraubTech
The header only sees what the exhaust port can flow. Heads.
To 383 suggestions-dyno
Old Aug 7, 2014 | 08:18 AM
StraubTech's Avatar
StraubTech
Yours is a good example as the AFR heads don't like much split as the exhaust port flows very well.
Old Aug 7, 2014 | 08:29 AM
augiedoggy's Avatar
augiedoggy
You never did answer which heads your using now? Are they the procomps?
Old Aug 7, 2014 | 08:54 AM
StraubTech's Avatar
StraubTech
Not ProComp anymore they are Speedmaster. Why would you change your name after being in business for over 15 years?
