over heating need help
Old Jul 26, 2002 | 08:07 PM
MIDNIGHT BLUE's Avatar
MIDNIGHT BLUE
Default over heating need help
i have a LS6 in my 70 vette p/s pb, and a/c the stat is 160 the temp gauge is reading 200 when i stop and shut the car off it's antifreeze out the over flow time. :U jim
Old Jul 26, 2002 | 10:00 PM
daily_driver's Avatar
daily_driver
Default Re: over heating need help (1970LS6)
im not familiar if the 1970 system had an expansion tank or not??
is yours missing?
Old Jul 26, 2002 | 10:01 PM
daily_driver
Default Re: over heating need help (daily_driver)
200 is normal......
Old Jul 26, 2002 | 10:05 PM
SLICKMAN's Avatar
SLICKMAN
Sounds like a bad rad cap to me.. Spend the $15 and purchase a new one, cheep fix to start. If that did not fix it, it was only $15 bucks..
Old Jul 26, 2002 | 10:25 PM
1970 Dave's Avatar
1970 Dave
Lots of possibles
1.Drain radiator,fill with 25% antifreeze,75% distilled water, and a bottle or two of "water wetter"
2. New radiator cap
3.Remove front license plate bracket if your state allows only 1 plate
4.Check all radiator support seals and replace if necessary
.More drastic measures if still not cured or satisfied such as:
1.Hi Flow water pump--several good brands(check Jegs or Summit)(beware a new hi-flow water pump may knock things loose and you will have heater core problems)
2. Remove radiator and have it rodded out--many years old
3.New aluminum radiator--several good brands(a bit spendy though)
Other members may have other ideas-not an uncommon problem with the Corvettes
SEMPER FI--1970 Dave :)
[Modified by 1970 Dave, 8:28 PM 7/26/2002]
Old Jul 26, 2002 | 10:37 PM
Juliet's Avatar
Juliet
Have you let it belch itself and then settle down to a lower level? They tend to increase in temp after you shut down since the fans aren't running and the block is heat soalked. I know on occasion when I've overfilled mine it belches once or maybe twice and then it's fine. ~Juliet
Old Jul 26, 2002 | 10:48 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Default Re: over heating need help (Juliet)
Sounds like my Vette when I bought it. If you're running a consistant 200 then I'd bet a 160 thermostat is always open.
I removed the stat & installed a Moroso restrictor plate and stock aluminum over flow tank. I run about 130-140 now & no vomitting! :D
To over heating need help
