colapsed vacum lines
Old Aug 8, 2014 | 02:46 PM
sgt kohler's Avatar
sgt kohler
Default colapsed vacum lines
lets see , I started off changing the rear leaf spring on my 77. i ordered a new 9 leaf spring , spring mounting bolts, a new mounting plate. and new spring bushings and bolts. the spring came out fairly easy using the tutorials that I searched on this site. had to cut the bushing bolts they were not coming apart. every thing went well until we went to put the new mounting bolts in the rear to hold the spring in and found i was sent too short of a bolt. yea like maybe 1/2 -3/4 too short so I cleaned the old ones up and put them back in. cranked the car up and moved it back a forth a bit then put it on the kwick lift to tourque the bolts and I noticed a vacuum leak by the pcv valve I had bought at pep boys that looks like an oil cap.. my buddy was there and I went to show him how well my headlights work since I fixed the vacuum system, and they didn't work. I traced the problem to the large vacuum canister line where it splits at the vacuum check valve. the new vacuum line had collapsed and looked like a piece of licorice. my car runs at 178 degrees . ive checked it with a heat temp gun and ac thermometers. heres what I think happened. besides the really really cheap vacuum line that came with the kit the heat from my new side pipe headers comes straight up to where all that stuff is sitting by the back of the drivers head. solutions anyone?
Old Aug 8, 2014 | 02:54 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Reroute your vacuum line or wrap your headers.
Old Aug 9, 2014 | 12:47 AM
76CSRvette's Avatar
76CSRvette
To colapsed vacum lines
