Installing side vents 81 C3
Old Aug 9, 2014 | 10:50 PM
JustinWC80's Avatar
JustinWC80
Cruising
Default Installing side vents 81 C3
The side ac and heat vents in my 81 are in need of replacing. How difficult are they to replace? Does it require a dash removal to a point? Or do they pop out fairly easily. Always appreciate the expertise here.
Old Aug 10, 2014 | 09:46 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
They mount from the rear of the dash. Not much room to work back there.
Old Oct 16, 2014 | 09:11 PM
JustinWC80's Avatar
JustinWC80
Cruising
Any tips or advice on install. Just want to replace the plastic adjustable side vent.
Old Oct 18, 2014 | 11:29 AM
Easy Mike's Avatar
Easy Mike
Originally Posted by JustinWC80
...Any tips or advice on install....
There's where you're going. AC ducts will have to be removed before you get there.
Old Oct 18, 2014 | 01:28 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
I'll add to Mikes picture and post.. When you go back together be careful not to strip out the holes in the dash pad. If you though, all is not lost. Find some plastic fusion or plastic weld and you can repair them easy. The trick with holes behind the dash pad is to fill the hole with the fusion, and then put the screw in while it is soft.
Willcox
To Installing side vents 81 C3
