69 Vacuum Wiper Door
Thanks.
Ron
It could be several things…
To start you may want to check the operation of the vacuum control valve that's mounted in the right side of the wiper bay. It's black plastic with a button and vinyl 'bellows' at one end. It has 3 small vacuum hoses hooked to it.
When the wiper arms move to the 'park' position the right side arm pushes a button that signals that the arms are fully down and the door can close without hitting them. The wiper door vacuum relay won't operate until it receives that signal.
To do a simple test of the valve you need some sort of vacuum pump with gauge like a Mity-Vac. Do you happen to have one?
If the control vale checks out the vacuum relay for the wiper door would be the next thing to check.
Regards,
Alan
I apologize for not getting back to you sooner. I've been working on a website for vacuum troubleshooting and I should have it up later this week. Here's how to check your safety valve.
1 - Remove your wiper grill, should have 8 screws and it will lift off.
2 - Mark and remove the 2 actuating vacuum hoses (5/16) from the wiper door actuator.
3 - Carefully lift up on the wiper door, and pull it up about halfway.
4 - You will find the safety valve underneath the passenger wiper arm close to the base. It looks like this;
5 - Ignore the port and it's hose nearest to the plunger. It is only a vent. It shouldn't be plugged.
6 - Hook up your Mityvac to the middle port, and mark the hose.
7 - Disconnect and block the bottom port. I use a short section of hose (3/16) with a plug in one end.
8 - Pump up your Mityvac. It should evacuate all vacuum and hold it. My guess is yours will fail this test.
9 - If you pass the #8 test, reconnect the bottom hose. Activate the wipers and stop them with the override in the up position. With the Mityvac still connected to the middle port, pump it up again. It should hold vacuum.
Report back.
ps where are you located?
1. With the button pushed IN…. the unmarked nipple should be closed and thus hold vacuum. The other 2 nipples (red/white) should be open and thus not hold vacuum.
2. With the button OUT….the white marked nipple should hold vacuum. The red marked nipple and the unmarked nipple should be open and thus not hold vacuum.
3. The nipple with the red mark is open no matter if the button is in or out.
Regards,
Alan
Hi, I see Dave has replied so disregard this test method..
Thanks again.
Ron
Long answer, maybe. There are 3 separate valves (switches) that can eliminate vacuum in the control hose going to the wiper door relay. The relay moves the actuating vacuum to the actuator ports front and rear by vacuum/no vacuum to the control (small) port. If by bypassing the safety valve the door still stays up, there are other issues that cannot be diagnosed this way.
It's always best if you can test each component for vacuum leaks separately mimicking their actual operation.
Originally the vacuum system was so leak free that the doors and headlights could even be operated the next day after the engine was shut off using the vacuum from the storage tank.
The system is designed so that as vacuum is lost in either the control side, (small hoses, switches and relays), or servo side, (large hoses, and actuators), the doors stay where there are as the vacuum is lost.
Winking headlights and a dancing wiper door are the result of components not working the way they were intended.
Regards,
Alan
