Speedometer gear
Old Aug 11, 2014 | 08:06 AM
AirborneSilva's Avatar
AirborneSilva
Default Speedometer gear
Hi Guys, what color/tooth count do I need for a 76 4 spd with 355 rear gears? Thanks
Old Aug 11, 2014 | 11:12 AM
MelWff's Avatar
MelWff
What is the tire diameter or tire size?
Old Aug 11, 2014 | 11:36 AM
JagNorb's Avatar
JagNorb
I too need to know the tooth colors for both the sriven and drive gears for my '79 C3. I have a 700R4 transmission an 28" diameter wheels.Tire size 275/60/15.
Thanks in advance.
Norb
Old Aug 11, 2014 | 11:58 AM
Mike Ward's Avatar
Mike Ward
There's a chart in the AIM that shows which gear is required.
Old Aug 11, 2014 | 12:18 PM
AirborneSilva
Thanks Guys, Yes even thank you to you too Mike I'm just looking for the stock gear as it was dead on with my tires (which I believe are stock height). I'll comb through the AIM to see what I can see.
Old Aug 11, 2014 | 02:19 PM
JagNorb's Avatar
JagNorb
I called Bowtie Overdrives to get the new speedo gears for my '79 that I am converting to a 700R4 transmission. My rear end is a 3:55, and my rear tires are 28" diameter, size 275/60/15.
Bowtie said my drive gear is 15 teeth and driven gear is 38 teeth.
Old Aug 11, 2014 | 06:09 PM
AirborneSilva
thanks
Old Aug 12, 2014 | 07:51 AM
Street Rat's Avatar
Street Rat
here you go...
http://willcoxcorvette.com/instructions/1975-1977.JPG
Old Aug 12, 2014 | 08:13 AM
AirborneSilva
Originally Posted by Street Rat
Hey thanks Rat I didn't have time to look in the AIM yesterday after work so this helps greatly!
To Speedometer gear
