power steering pump keeps going out...
Here is a list of parts I've saved on my Summit Wish List:
http://www.summitracing.com/parts/sum-340201
i like the mount, but it says long neck water pump, not short??? will it still work? and it says to 76?? i do not believe there were any changes to a sbc from 76-79???
paste:
Brand:Summit Racing
Manufacturer's Part Number:SUM-340201
Part Type:Power Steering Brackets
Product Line:Summit Racing® Correct-Align Power Steering Pump Brackets
Summit Racing Part Number:SUM-340201
Power Steering Pump Model:GM Type 2 (Saginaw TC series)
Bracket Style Upper and lower
Power Steering Pump Mounting Position Driver side
Hardware Included:Yes
Bracket Material:Billet aluminum
Bracket Finish:Polished
Quantity:Sold as a kit.
Notes:Fits General Motors type two pump.
In-Store Pickup:Choose In-store pick-up (OH, GA, NV) on our web site.
These Summit® Correct-Align polished aluminum power steering brackets make pump installation easy. These high-quality, adjustable billet brackets offer superior fit and finish. The Correct-Align brackets adjust front-to-back a full 3/4 of an inch to compensate for differences in variations of water pumps, dampers, and end-of-head machining tolerances. These brackets are designed for easy bolt-on installation and do not require drilling any holes in the cylinder heads. All Correct-Align brackets come complete with fasteners.
Make:CHEVROLET
Beginning Year:1967
Ending Year:1976
Engine Type:V8
Liter:5.7
CID:350
Engine Size:5.7L/350
Engine Family:Chevy small block Gen I
Water Pump Style:Long
Belt Style (application):V-belt
Duane
Duane
Jim
Nice clean install. Easy to adjust belt, shorter belt required Gates part " 7325".
. I needed to have spacers to compensate for the long water pump,{which will be needed for the third belt set up}. I don't know why I can't load more than two picts per post. They are 130.4KB and JPG maxs at 2.86 MB[ computer skills at idiot level]
. After blowing the resivor apart OEM, installing a lesser expensive pump and blowing that apart even though LT1 member said the OEM was sufficient, but I don't know any OEM application over 6500RPM red line. I'm chipped at 7400, shift lite at 7200 RPM. T
. After blowing the resivor apart OEM, installing a lesser expensive pump and blowing that apart even though LT1 member said the OEM was sufficient, but I don't know any OEM application over 6500RPM red line. I'm chipped at 7400, shift lite at 7200 RPM. TAnyway..... i went out and purchased a power steering filter for a Toyota truck.... I figure, although the system has been flushed now like 4 times, the only thing I can still think of that is holding down the pressure regulator is containments in the system....so I installed it... I have had 4 lock-ups since but each having a lesser and lesser effect and time until the unit can open up again... now, for the last 2 days, and about 20 miles she has run perfect... this is the longest time as of yet... I do believe the filter is working... it has both filtering in it as well as magentas for iron...im filtering off the hydroboost but not the rac...
