bolt size front harmonic balancer
Old Aug 13, 2014 | 06:13 PM
rosros's Avatar
rosros
Default bolt size front harmonic balancer
Purchased the crankshaft rotation adapter http://www.jegs.com/webapp/wcs/store...archTerm=80743 in order to turn over the engine by hand while the harmonic balancer is still attached. Does anyone know what size bolts I would need to attach the crankshaft adapter to the front of the harmonic balancer threaded holes?
Old Aug 13, 2014 | 10:06 PM
LT-1 kid's Avatar
LT-1 kid
the hole in the crank is a 9/16 tight thread, with a 5/8 bolt head, if that helps
Old Aug 13, 2014 | 10:34 PM
Mooser's Avatar
Mooser
The 3 bolts that hold the pulley on (where that adapter bolts) should be 3/8-24 (fine)
HIH
M
Old Aug 30, 2014 | 09:55 AM
rosros's Avatar
rosros
HIH
M
Thanks, went to Ace, picked up the bolts and worked like a charm. Unfortunately could only turn the engine over 3/8 around before it stops.
To bolt size front harmonic balancer
