inaccurate fuel guage sender
but the dash gauge still shows under the full mark when filled to the brim.
so according to the willcox papers,
"For a fuel gauge from 1968-1976 to function properly you must
have 0 ohms when empty, 45 ohms at one half a tank and 90 ohms at full tank."
i have refilled the tank, and when filled to 1/4" under the fill tube,
i'm only getting 76ohms on a test meter between the sender pin and ground.
so does that mean that i'll have to remove the sender and bend the float arm down slightly to get a fuller reading?
also the pickup sock n tube appears to sit high in the tank, ie; leaving a fair amount of fuel behind at "empty"...
To me, it sounds like the sending unit is not adjusted properly, or maybe it was bent before you installed it.
the '67 stalled out on the street right in front of my house 2 years ago. I thought it was the plugs and embarrasingly replaced them right on the street. I car still didn't fire. Gas gauge read over half. Don't know why, but I checked the tank with a flashlight - dry as a bone. Put gas in and it fired right up
I now visually check the tank before I use it and use the odometer figuring how much I'm still good for. YMMV
I found that the float on a replacement sender wasn't as buoyant as the original so I moved the old float to the new sender arm. It now floats on the surface of the gas giving an accurate gauge reading.
The end of the filter 'sock' rests on the bottom of the tank.
Regards,
Alan
