Back up lights adjustment
Old Aug 15, 2014 | 07:30 PM
croaker's Avatar
croaker
Default Back up lights adjustment
I'm looking for the back up light adjustment procedure. I found it a while back but forgot where. It involved lining up a pin in the lever arm. Thanks in advance
Old Aug 15, 2014 | 09:24 PM
croaker's Avatar
croaker
Anybody? I have them adjusted just looking for the information for next time.
Old Aug 15, 2014 | 09:46 PM
76CSRvette's Avatar
76CSRvette
DID YOU check Wilcox site. Are you talking about the tail light adjustment or the wiring
76CSRvette's Avatar
76CSRvette
http://forums.corvetteforum.com/c3-t...tment-how.html
Old Aug 15, 2014 | 09:51 PM
croaker's Avatar
croaker
Mines a 4 speed. I found it Thanks
Old Aug 17, 2014 | 07:12 AM
C3 4ME's Avatar
C3 4ME
you should just be able to loosen the 2 screws that attach the switch to the trans, then just rotate the switch until they work correctly. I wound up having to enlarge the slots on the switch on my 79, and it took a lot of fiddling around, but I finally got them working correctly.
Old Aug 18, 2014 | 09:05 PM
croaker's Avatar
croaker
That's how I did it but, I was looking for a procedure I had read in the past. Thanks for your input.
Old Aug 19, 2014 | 10:02 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
http://willcoxcorvette.com/repairand...lp.php?hID=155
click on supporting document.
Willcox
Old Aug 19, 2014 | 06:12 PM
croaker's Avatar
croaker
Willcox
That's where I found it.
To Back up lights adjustment
