Engine Guru's - help needed
Old Aug 17, 2014 | 01:03 PM
V4motorsports's Avatar
V4motorsports
Default Engine Guru's - help needed
Have a 71 350/270, absolutely stock!
Have a miss that I can't find.
Heres what I did so far: New plugs, new wires, new distributor cap & rotor, new points. Replaced carb.
Start engine and running rough, very rich, and you can hear the miss in the left exhaust pipe.
Did a compression test last night and here are the results:
#1 135 #3 140 #5 142 #7 140
#2 150 #4 150 #6 150 #8 145
Any thoughts?
Russ
Old Aug 17, 2014 | 02:27 PM
Patro46's Avatar
Patro46
Yes. The compression seems great on all cylinders. This rules out mechanical issues. Id pull a plug wire one at a time with the engine running and see if I had a cylinder not hitting. If so check spark plug and wires. If they are all hitting, about all that's left is the carb.
Old Aug 17, 2014 | 02:32 PM
bluedawg's Avatar
bluedawg
My thoughts exactly except another thing is to start it in the dark and maybe you'll see it arking. Good luck.
Old Aug 17, 2014 | 03:44 PM
augiedoggy's Avatar
augiedoggy
About a week ago I noticed mine wasn't idling right either . I was constantly messing with the idle and I finally pulled the carb apart to find all kinds or crap floating around in the float bowls partially clogging jets on and off.... Something to look at. The ethonal gas turns to a clear jelly as it its up aluminum too...
Old Aug 17, 2014 | 04:42 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Another method of finding a dead cylinder is to put some water in a spray bottle and squirt a small amount on each exhaust until you find one that doesn't steam. I like this a lot better than potentially getting bitten by live wires. Of course, it works better with headers, but you should still be able to tell with iron manifolds.
Old Aug 17, 2014 | 08:45 PM
bluedawg's Avatar
bluedawg
Nice trick. I have a set of insulated pliers made specifically for pulling plug wire while the engine is running, works better than getting shocked and pissing your pants.
Old Aug 18, 2014 | 02:33 AM
terrys6t8roadster's Avatar
terrys6t8roadster
My 6t8 had a misfire, did all of the above and found the problem to be excessive run out in the distributor shaft causing erratic dwell variations. Supposed I could of had the dizzy rebuilt but went with MSD ignition. Cleaned up immediately. Just something for you to check. Converting to the electronic pick up could also help. It doesn't care about shaft run out. T
Old Aug 18, 2014 | 02:57 AM
pltmgr's Avatar
pltmgr
No guru here but a "miss" would lead me more to electric vs carb. Few times over the years I discovered I cracked a new plug during installation. Few times I found the new plug wires were not fully seated on plug or dizzy. Running in the dark helped me a few other times.
Old Aug 18, 2014 | 04:15 AM
V4motorsports
Thanks for all the replies guys, really appreciate it.
My thinking is: if it were an electrical problem, wouldn't I hear the miss in both tailpipes?
Do you think, with the lower reading in #1, it could be a weak valve spring or sticking valve?
Thanks, will try all the above later today.
Russ
Old Aug 18, 2014 | 05:36 AM
Cavu2u's Avatar
Cavu2u
I'll bet ya used that method on Lycomings & Continentals too.
From a cold engine, start it up & run it for 20 seconds, then off. Maybe the touch method can then point you to the missing cylinder. Otherwise, an infrared thermometer might tell you too.
Steve
Old Aug 18, 2014 | 09:17 PM
gcusmano74's Avatar
gcusmano74
Russ
A fuel/air/carb problem would not have a rhythm to it. Any miss that seems to happen in some sort of rhythm has to be electrical or mechanical.
Those cranking pressures are easily within tolerance. Chevrolet allows, I think, the lowest reading cylinder to be 75% of the highest reading. So, in your case, 135 divided by 150 is 90%. You're fine there.
Although, at 42 years old, I think that you really might have a cam lobe going away on you. That's a typical way for a SBC to need a rebuild.
Old Aug 25, 2014 | 12:00 PM
V4motorsports
Here is a video of the engine running:
https://www.youtube.com/watch?v=Mjz9...ature=youtu.be
As you can see, as soon as I let off the throttle, it quit running. The RPM's are fluctuating between 750 & drops down to 500 and it still smells terrible (lean/rich).
This thing is really starting to drive me crazy!
Russ
Old Aug 25, 2014 | 01:15 PM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
Have you pulled a valve cover yet? You could have a collapsed lifter, or wiped a lobe on the cam. There also could be a loose rocker, but you should hear that.
Old Aug 25, 2014 | 01:33 PM
F22's Avatar
F22
"There also could be a loose rocker, but you should hear that"
True! Also, grab each rocker while it's hot and see if any are far looser than the others, that's how I found my loose rocker.
To see if you have a wiped cam or collapsed lifter, take off the valve covers and check each rocker. The one that's hardly moving, in comparison to the others, is the wiped lobe or collapsed lifter. Then, when it cools down, you pull the rocker arm, carefully pull out the push rod and then looking down into the lifter valley, go in with a pair of long needle noise pliers or a long pick in the lifter hole on top, pull the lifter and look at the lobe. If it's rounded, it's toast.
Old Aug 25, 2014 | 01:37 PM
F22's Avatar
F22
Also, I highly recommend a spark plug tester, that works while the engine is running. You simply hold the end of it, against the plug wire and you will see a flashing light inside the glass tube. It will instantly tell you, whether a spark plug wire is dead or weak. It's shaped like a pen and very easy to use.
Amazon.com: Lisle 19380 Spark Tester: Automotive Amazon.com: Lisle 19380 Spark Tester: Automotive
Old Aug 25, 2014 | 07:25 PM
nomocrap's Avatar
nomocrap
I had a weird miss on #2 cylinder, Checked plugs, plug wires, valves, changed distributer, used a heat gun on headers, removed carb and scoped the combustion chamber and found no problem still having a miss and a cold cylinder. last resort took carb 4150 holley apart, used air to blow out passages in carb and poof out came a piece of metal. Put carb back together and back on engine, and no miss or cold cylinder. Good luck JAY
To Engine Guru's - help needed
