Vacuum issue
Old Aug 24, 2014 | 04:47 PM
npatton's Avatar
npatton
Navigator
Default Vacuum issue
After owning my 1972 roadster for 35 years I have a sudden vacuum issue. Yesterday both my headlight doors and the wiper door failed to open. The vacuum at the manifold is 14 and at the large outlet on the check valve however the small side is showing nothing. I believe this is the issue but was hoping to get a second opinion. Since I opened the headlights manually is there a special trick to closing them?
Old Aug 24, 2014 | 05:50 PM
'75's Avatar
'75
Sounds like you need a new check valve. You should be able to put a T in place of it for testing purposes, till you get the new check valve.
Old Aug 24, 2014 | 05:55 PM
Sayfoo's Avatar
Sayfoo
You should be able to reach up under the headlight assembly (under the bumper) and pull on the linkage to release it. A knee action joint that over travels to lock up. On my 69, the linkage extends past the pivot point about 1 1/2" and there is a hole through the hub.
Old Aug 24, 2014 | 08:28 PM
npatton's Avatar
npatton
Navigator
Thanks that worked.
Old Aug 24, 2014 | 08:29 PM
npatton's Avatar
npatton
Navigator
Ok thanks.
Old Aug 25, 2014 | 07:31 PM
Sayfoo's Avatar
Sayfoo
You can also reach under and push on the linkage to open if you ever have a problem getting them to pop up
To Vacuum issue
