68 wiring problem
Old Aug 19, 2014 | 12:22 AM
530planeman's Avatar
530planeman
Default 68 wiring problem
I have been straightening the wiring behind the gauges and have a 2pin female connector with a black and a brown wire anyone know where it might go ?
thanks
Old Aug 19, 2014 | 06:07 AM
pnewt's Avatar
pnewt
Default 68
I had to re do the wiring on my 68 also and got lots of help here on the forum. I also have the 2 pin loose and was told it was for an accessory that I do not have- everything works on gauge area so I assume that to be true. Amazing how the 68 is different than any other Corvette I've had. Yesterday, I found a loose wire under the hood near the wiper motor that acts as a ground for the horn but attaches to one of the studs for the wiper motor??? Good luck
Old Aug 19, 2014 | 09:57 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
The wire Newt is talking about would be the wiper over-ride lamp. but this was a single black wire with a socket on the end of it. It operated the over-ride warning lamp in the dash by picking up power on the black wire when the motor is in the over-ride position.
Possibly the Tach solenoid connector on the back of the tachometer.
With this unplugged the wipers wouldn't work unless it's been by-passed.
Does the connector look like this? Do the wipers work?
Old Aug 19, 2014 | 10:35 AM
530planeman
Thank you very much for help .Yes connector looks like the one you pointed out .My next project is to get wipers working .
Thanks again
Wes
Old Aug 19, 2014 | 04:43 PM
530planeman
Thanks again
Wes
Hi
working on wipers have put in new switch still not working .I am not very good at wire diagrams but have found most components except one relay . I have power at large red wire on connector with 3 pins and power when I turn on wipers at three pin connector ,center pin ,at wiper .I took wiper assy.out now on bench how can I test it ? There is a relay just behind brake booster on firewall with nothing to it and a pink and green connector coming out of firewall female connector taped off hooked to nothing
Old Aug 20, 2014 | 04:04 PM
DZRick's Avatar
DZRick
Hi
I believe the relay you're looking for is under the shifter console, toward the front, in front of the radio.
Here's Willcox's '68 wiper motor bench test video.
Old Aug 20, 2014 | 05:34 PM
530planeman
http://www.youtube.com/watch?v=XpkbCGkFaJs
Thank you very much I will perform test as per video and let you know .My wiper motor has no washer pump on it ?? but has correct part #
Wes
Old Aug 20, 2014 | 08:06 PM
530planeman
Wes
Hello
Well I can only get the motor to run if I put power to the brown wire ,it will run on high and low speed .I took the plastic assy. apart where the points are and everything looks ok ? any suggestions .
Wes
Old Aug 20, 2014 | 08:25 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
The fact that the motor works at all is a good thing. If I was at home I would take a pic of how I have mine retired. P m me tonight and remind me to post a pic if you do not get it working correctly.
I read that the '68 wiper motor has a constant 12v positive wire connected to it.....so the wiper switch mainly switches the ground connection to the speed that you select on the switch.
Since Bubba did away with my wiper door and all the electric items, I had to rewire that part of the harness so the wiper motor woul. Work correctly with the relay under the center console/the wiper switch above the gauges /and the sub-harness that connects to the wiper motor.
Old Aug 20, 2014 | 08:57 PM
530planeman
Hey thanks for the info .I am a pretty good hand on how this system works .probably can't talk to the GM guy who designed this system because if he is not dead I am sure he is locked up in a mental institution .I think I can get everything working correctly with a little more work .just have to get the Battery and wiper motor with all the jumper wires off the kitchen table or no dinner .talk to you later
wes
Old Aug 20, 2014 | 10:00 PM
530planeman
Default 68 windshield wiper problem
DZRick
what I found was there is a small set if contact points in the plastic housing and do you happen to know how mich gap they should have on them?
Wes
Old Aug 21, 2014 | 12:02 AM
DZRick's Avatar
DZRick
DZRick
Wes
Sorry,I don't.
I'll reread your previous post when I have time and see if I can help you out. It's been a couple years.
Old Aug 21, 2014 | 01:04 PM
530planeman
Still working on wiper problem .The motor does operate on bench the problem I think is in the small piece with the contact points in it ? If i see correct when power goes to the yellow wire it clicks and the solenoid allows the points to touch and then power can go from the hot red wire across to the black and red wire which powers up the motor ? when power to yellow wire is gone the solenoid pops and power is cut from red hot wire to black and red wire to motor Does the tach solenoid have to be in a certain position ? When I check the brown with white stripe wire it shows grounded back to the tach. solenoid ?? is this correct ?Is that assy. with contact in it available by it's self ?
It's a good thing I am not charge a customer to solve this problem because if i gave him a bill for my time he would just say it's your car now
Thanks for help .
Old Aug 21, 2014 | 04:46 PM
530planeman
Sorry,I don't.
DZRick
After further investigation I think part of the problem is ,thru wear and age, the little point contact in the transmission part of the motor are not disconnecting when i turn off motor to park the wipers ?? I took everything apart(My mom said I always did that as a kid only now I put it back together) and see how this unit functions .I am going to try to bend the little arm on the point contact to see if that helps .I swear the guy that designed this is locked up in a mental home ??
Thanks Wes
Old Aug 21, 2014 | 08:24 PM
DZRick's Avatar
DZRick
Hello
Wes
It sounds like you are back feeding the motor on the brown wire, The brown should only have voltage when the motor is running
Thanks for help .
the brown with white is a ground and goes to the wiper override switch, not the solenoid.
The solenoid on the back of the tach controls the vacuum to the wiper door.
I'd see if you can get the motor to correctly bench test before tearing more stuff apart. Just a suggestion.
Old Aug 21, 2014 | 08:40 PM
530planeman
Default wiper on 68
I did perform a bench test with the Willcox info. and everything works ok except it will not park and shut off which I think is due to the fact that the arm in the plastic case does not go far enough to break the connection to the little contact that feeds power from red wire to motor .I am going to try to make an adjustment on that little contact next .I am also going to clean and check all grounds on the car next .
Thanks for help
Wes
Old Aug 22, 2014 | 08:19 PM
DZRick's Avatar
DZRick
Hello
Wes
I guess I misunderstood, it sounded like you could only get it to run by putting power on the brown wire.
Thanks for help
Wes
I'm almost positive Willcox touched on what to check when a motor wouldn't park.
Don't break anything.
I'll be back
To 68 wiring problem
Old Aug 22, 2014 | 09:07 PM
530planeman
I'll be back
D Willcox covered it on 69 when it keeps running .I see the problem now and I think I can fix it .The park arm is not going in far enough to break the contact points so I will try to bend point arm good thing everything comes apart easy .i now know how the system works and again thanks for the help hope to meet you some day .shoot me youe e mail and i will send some pictures which you are welcome to post as I am working on how to post them .Have a good one .
Wes
Old Aug 22, 2014 | 09:17 PM
DZRick's Avatar
DZRick
Sending you a message with my e-mail.
Old Aug 23, 2014 | 02:00 PM
0Willcox Corvette
Former Vendor
Okay.. been reading through this today.
When you bench test exactly as shown in the video, and when you ground the green with the blue wire ground removed, it won't park. Is this correct?
I also thought you said, you powered up the brown wire to get the motor to run..
Willcox
