Vacuum to brake booster
Old Aug 20, 2014 | 11:16 AM
JimT's Avatar
JimT
Default Vacuum to brake booster
I've noticed that when the car is idling (in neutral) and I depress the brake pedal, the engine increases rpms - 100 - 200 rpms then settles back to the normal 800 rpm setting. The car is an automatic and the brakes seem to work fine. I have just noticed this, so is this a common engine response or do I have some kind of minor vacuum leak, ie brake booster diaphragm, check valve, or hose. Any comments would be appreciated.
Jim
Old Aug 20, 2014 | 11:31 AM
MelWff's Avatar
MelWff
that is a normal response in any car from that era with power brakes.
Old Aug 20, 2014 | 12:25 PM
7T1vette's Avatar
7T1vette
That sympton would indicate that the vacuum booster wasn't holding the vacuum completely. It does not mean that the booster is 'faulty'...just that the seals are a bit worn. There should be no issue of brake function or safety.
If that condition worsens significantly and you become more concerned, you might want to replace the booster unit.
It might also indicate that your carb is running a bit 'rich' at idle, and the added air from the booster (when the brake is applied)...along with the excess fuel in the [rich] intake charge...causes the engine to rev just a bit.
Old Aug 20, 2014 | 12:35 PM
F4Gary's Avatar
F4Gary
2018 C3 of Year Finalist
2016 C3 of the Year Finalist
Hmmm, my car's idle increases a little when I pull the vacuum hose off the white filter.
Old Aug 20, 2014 | 02:39 PM
1969RAY's Avatar
1969RAY
2025 C2 of the Year ('63 and '67) Finalist - Unmodified
C2 of Year Finalist (appearance mods) 2019
When I brake hard (while driving) my rpms drop-sometime significantly so that I have to feather in some accelerator to keep the motor running.
Old Aug 20, 2014 | 11:38 PM
7T1vette's Avatar
7T1vette
When you apply the brakes with a power-brake system, the vacuum in the servo booster 'works' to assist with the apply force. If the booster is well sealed, there should not be any loss of vacuum or transfer any air between the booster and the intake. But years of use wear seals, and eventually, they will begin to leak a bit. That would allow excess air to enter into the A/F charge in the intake system. And, extra air put into a balanced fuel charge will lean it out.
Old Aug 22, 2014 | 05:47 AM
JimT's Avatar
JimT
Thanks 71vette, great explanation. I believe the brake booster is the original unit. Maybe it is time to replace....
Old Aug 29, 2014 | 01:19 PM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
I have a question. When I pinch my vacuum hose between the intake manifold and booster, the engine dies. Is this normal?
To Vacuum to brake booster
